Stylus not working when touching screen - Computers & Internet
  • 6 more comments
  • droberts489 Aug 30, 2008
    I have spent entire day trying to get my palm set up and the stylus still will not do anything on the screen in spite of the fact that I have done the target thing hundreds of time. I did it when it first came up and after the palm was hotsynced. Now all that comes up on the screen is the target thing. I don't even get the main menu page anymore. When I look at the hotsync log, everything looks OK, but now it won't even hotsync anymore. It is virtually useless.
  • Anonymous Sep 15, 2008
    I have exactly the same problem.
    Can't even do a hard reset.
    Sadness.
    Do I have to buy new one?
  • Anonymous Nov 06, 2008
    touch screen doesnt not work
  • moonisb Dec 12, 2008
    My screen is totally frozen, I can only access the software via the qwerty keyboard, I've soft reset and taken the sim and battery out many times.
    Any suggestions anyone?
  • Anonymous Mar 14, 2009
    wont work when touching the screen
  • Anonymous Apr 27, 2009
    This morning my Zire 21 quit responding to touch screen inputs. Did soft reset 3 times no resolution.
  • StephiRu Apr 28, 2009
    Same problem here. Mine started reading my inputs wrong, so I re-digitized it by tapping on the targets and it seemed ok. I had to do this several times. Then I went to turn it on and my keylock was on. I could not get past that point. Then I did several soft resets to no avail. I have considered letting it die, as that has worked for other problems in the past. Ug. Any help?
  • joezias May 05, 2009
    when I try to enter data with the stylus, it does not always respond or does not rewspond to certain letters.
I encountered this problem today, and I have figured out a solution!
Switch the Wireless switch on the bottom of the Pocket PC to the Off position, then back on.
Voila, your touch screen should respond now.
Posted on Apr 23, 2009
    New Friend:
My o2 xda orbit's touch screen is not working.... i have done everything.... had updated the system also but no results.... plz help me out with good solutions....plz
Posted on Nov 08, 2009
6ya staff
SOURCE:
Stylus pen using on adobe photoshop
If it is a resistive touch screen you can use anything as a stylus. To test if it is resistive touch it with a non conductive material like something made of wood or wear a glove. If it doesn't work then it is a capacitive touch screen and then you just need to buy any capacitive stylus and yes it will work. Photoshop should work fine too.
Jul 04, 2013 | HP Pavilion TX2110US PC Notebook
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going...
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Nov 28, 2009 | HTC Touch HD Smartphone
How do I change the sensitivity to the screen so that I can use my longnails & not my finger?
you will not be able to use your fingernail on the hero screen. the touch screen is similar to the iphone (capacitive) and different to most other touch screens that use a stylus (resistive).
your finger is required for the screen to pick up where you touch.
there is a special stylus you can buy that will work, but make sure it is specifically for the iphone. a standard plastic tipped stylus will not work.
Nov 19, 2009 | HTC Hero Smartphone
Stylus
Its not the styles it the ds
May 22, 2009 | Nerf Stylus Twin Pack for Nintendo DS...
Touch screen is not responding on my x1
ur TOUCH PANEL IS FAULTY kindly go for warranty claim or tell me i can give u link for the out of warranty replacements
Mar 16, 2009 | Sony Ericsson XPERIA X1 Smartphone
Open Questions:
Computers & Internet Logo
2,063 people viewed this question
Ekse
Marvin
Marvin
