Question about Karcher Electric Cold Water Pressure Washer 2000 PSI 30 GPM Model HD
In the appliance karcher HD 2000 Super are 2 sensors include pumps and one emergency. What they have pressure?
4 Suggested Answers
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
wmpcs
  • 100 Answers
SOURCE: I have a Karcher HD
Yes, the unloader needs to be lubed. Send me a email at justin@wmpcs.com with a discription of what you just listed and I will send you a pdf file on how to repair it.
Posted on Nov 01, 2010
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
How do you change a rupture disk for karcher 3600 4.0 GPM
try putting a plug and then try again if you hear the pump not unloading when u release the trigger then the new rupture disk would rupture due to a faulty unloader you can use a pressure relief valve for a better replacement.let me know 30 years exp,
Jul 28, 2013 | Karcher HEX HD SCREW 1/4-20x1.25
Karcher K2.54M loss of all pressure
I have seen it before where the little plastic pistons overheat and melt. The unit still runs but with no pressure. I would pull the pump apart and check the pistons.
Sep 03, 2012 | Dishwashers
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
Motor running, water supply adequate but when
clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Jul 31, 2010 | Karcher 1750 Psi Elec Pressure Washer
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
Pressure surge on and off for 2 seconds w/ new Karcher
It can be one of three conditions,
  1. The water supply in is not sufficient
  2. The pump oil is low
  3. The seals are bad in the pump.
I would check the first one first as this is the most common problem.
The water supply hose should be a high volume hose of at least 1/2 inch but 5/8 inch or greater is best.
May 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Mar 07, 2009 | Karcher K2.26 Electric Power Washer
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Karcher Electric Cold Water Pressure Washer  2000 PSI 30 GPM Model HD Logo
71 people viewed this question
Top Karcher Tools & Hardware - Others Experts
John Trevino
Are you a Karcher Tool and Hardware - Other Expert? Answer questions, earn points and help others
