Question about Ricoh Office Equipment & Supplies
What is causing Service Code 565 ? and how do I clear it ? Ricoh Aficia MP C2500 S/No: L3674104206
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
  • 9 Answers
SOURCE: Installation driver for Ricoh Aficia CL7000 laser printer
go to www.ricoh.com, usa, downloads and then select your printer in the drop down windows, lastly choose your operating system. now just unzip the file and install
Posted on Dec 19, 2008
  • 161 Answers
SOURCE: service mode
call service --- possible bad thermistor (fuser)
could over heat
Posted on May 06, 2009
  • 95 Answers
SOURCE: Intermittent Ricoh color printer issue
Try the RPCS driver.
Posted on Jun 26, 2009
Ickoajnc
  • 203 Answers
Press the “Up/Down arrow” keys together for about 5 seconds, and then press the
“OK” key.
“SYSTEMver x.xx/ 1. Service” appears on the display.
The machine automatically goes off line when you enter the service mode.
enter SP 5810 and reset the SC 543 **** if again appears please do not reset it again because you may do bigger problem and damage more part than ware damaged in first place .
The SC code says that the termistor is damaged so check on the fusing unit dose the termistor is standing in good position or has dirt on the surface of he termistor.
RATE ME IF THIS HELP YOU
Posted on Jul 17, 2009
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
Why ricoh mp-c2500 not adding toner
The most likely cause is the toner pump has failed. There is no quick fix a service tech has to make the repairs.
Jun 23, 2014 | Ricoh Aficio Office Equipment & Supplies
Code sc 101 mp c2500
Optics problem check to see if mirrors are dirty. Will need to clean mirrors be carefully you can cause mirrors to fall out or become miss align . Buy a can of air blow them off . Turn off copier before you start then turn on and copier will move optics back into position.
Jan 15, 2014 | Ricoh Aficio Mp C2500 Copier
Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Jul 02, 2010 | Audio Players & Recorders
I have a Ricoh MP C2500 Copier and I can not select any functions on the menu when I press it with my finger
Your touch screen went bad. This is a common problem with many newer Ricoh models. Get in touch with your service technician to get a new screen.
May 26, 2010 | Ricoh Office Equipment & Supplies
143 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
