Question about Kenmore Elite HE5t Washer
My kenmore HE 5 model number 11047081600 has an error code of F20. No water in going into the drum. All the water is coming out of the front bottom by the door.
  • 185 Answers
SOURCE: Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Posted on Mar 28, 2008
SearsTechToo
  • 261 Answers
SOURCE: kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Posted on Sep 04, 2008
SearsTechToo
  • 261 Answers
SOURCE: KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Posted on Oct 23, 2008
SOURCE: F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Posted on Jan 17, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2T F20 plus Water leakage when tub starts to fill
Have you read by advice on how to diagnose this problem? Click on the following link:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you HAVE water entering the wash tub, first verify that you do not have a siphoning condition. This is where the drain line does not have the proper air gap to drain properly and creates a vacuum on the drain line. This will cause drain problems and may prevent the washer from filling all the way. Or, you may have trouble maintaining the water level. When you stated you had water leaking, is this a visible leak? Or, do you have water slowly draining from the tub? Double check your drain line to be sure.
Next, check the drain pump to ensure it is not clogged or obstructed which minimizes drain flow. Also, make sure the pump is running. Remove the access cover and clean out the pump reservoir. In addition, check the drain line from the bottom of the wash tub to the inlet side of the drain pump. I have personally found small articles of clothing stuck in this line, preventing drain flow.
Read through the link thoroughly. If you require additional assistance, please let me know before rating the solution. I hope this helps you.
Posted on Feb 02, 2009
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Error Code F20 blinking
Hello
I had to take the bottom panel off. There you will find a black squishy like filter. I unscrewed the the screw that holds it tight.
Be prepared for lots of water and suds, the water drains out quickly. I pulled out a wire from my daughrter's bra, that was plugging the filter. Re-attached everything, now it is working just fine. Happy in Maple Ridge.
Aug 21, 2008 | Kenmore 43142 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
70 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
