What does pe stand for ?LG washing machine - Washing Machines
    Brigadier General:
  • 6,277 Answers
'PE' in LG's stands for 'sensing water pressure error' (really useful- inlet or outlet?!)
I always suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 28, 2011
Error Code PE
go to the manufactures website and download the user manual and check in trouble shooting guide eric
Jan 19, 2018 | LG Washing Machines
My washing machine LG - model # T7517TEPT0 is displaying PE error - please advice to enable to fix the repair
PE stands for locked rotor meaning the motor is not able to turn either electrically or physically
May 01, 2017 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
Pe sensor error on lg washing machine
The best way to do is to call an LG service center regarding this problem.
Feb 01, 2014 | Washing Machines
Washing maschine runs for 5 sec and trip
PE code stands for "Pressure sensor Error" check the sensor and the small tube that is connected to the outer tub for debris.
Dec 18, 2013 | LG WM-2277HW Front Load Washer
PE error message LG Washing Machine
HOW OLD IS MACHINE??? LG is having problems with their motors on home appliances.
Louie Almond
Mar 27, 2011 | Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
PE - LG Washing Machine WFT7012EN
I am finding a PE error as I try to use my washing machine this morning. Is there any quick fix for this?
Apr 28, 2008 | Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
