Question about Smeg FAB28
I took the wiring apart on my fridge/ freezer model no fab28PB and now Idont know how to put it back as there are 2 blue wires please help
  • 436 Answers
I cannot locate schematics online but here is link to support. Please contact them for further help
http://www.smegusa.com/AfterSales.htm
Posted on Mar 28, 2011
  • eddiemattie Jul 29, 2011
    thanks anyway buddy but the closest thing i got there was a wiring diagram for some kind of lab lol
Kenmore fridge
Hi Missy Blues,
Your Fridge is in major need of defrosting. This will require you to clear the goods out of your Freezer temporarily. I believe you have a Problem with a component is the Auto defrost Circuit. First of all we need to get the frost out. Once you have the Freezer cleared, Turn the freezer off. Place a Hair dryer in the door of the freezer with its nozzle pointing at the back of the freezer compartment. Run the Hairdryer for a couple of hours blowing into the freezer with the freezer door crak open slightly. This should melt all the frist in your freezer. You will probably need some towels to help soak up water. Once the Freezer is defrosted. Remove the panel inside back of the freezer. The section under the icemaker. You will see a radiator coil. Disconnect power to the fridge. At the bottom of this Radiator coil you will see a device bolted to the bottom of the coil with wires going to both ends. This is your Defrost Heater. REmove it. It is a glass tube with a spring looking heater inside. If the spring parts is burned apart, the heater is bad, and that is your problem. Put all the goods back in your freezer, and turn it on. Go to Sears Parts store and get another defrost heater. You will need the model number of your Fridge. Good Luck
Nov 27, 2007 | Refrigerators
Fridge broken, freezer is temp. that fridge should
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 26, 2010 | GE GSS20IEP Side by Side Refrigerator
Frigidaire fridge freezer not getting cold
Louise, this is a big area. I would switch off the fridge, look at the back where you see the" box things". You should see a timer which is white or black (wires comming out of it).. It has a short type of knob which can be turned manually clockwise.. Turn about a 1/4 turn then try and switch on again. If not, thermostat will be the problem. Assuming you never disrupted any wires.
Nov 13, 2009 | Frigidaire Freezers
I have a GE side by side refrigerator GSS22JEMB BB. The defroster heater was replaced. How do I know if the defroster is working properly. Can I manually manually make the fridge go into defrost mode? Also...
To go into defrost manually : Remove the 10"X13" panel from the back of the fridge . You will see a plug with 3 larger wires going to it . Unplug this plug ( UNPLUG THE REFRIGERATOR FIRST ) . The blue receptical will look like this wire#1,wire#2, space , wire#3 . Use an insulated jumper inserted into the receptical to wire #2 and #3 . Plug refrigerator back in . You will be able to see the glow from the defrost heater if the freezer is cold enough and the bimetal is good .
Some models , when the freezer door opens , the fan will keep running and others , the fan will stop , until the door is closed .
There will be a slight stream of cold air at the top of refrigerator section due to the fact , that if it was a larger stream , food would freeze on the top shelf of the refrigerator section .
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Jan 05, 2009 | Hoover HCA390FFK Bottom Freezer...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Model TFX22ZPDAAA GE side by side
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Lakewood HV-18 fan... how to wire switch?
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
Oct 13, 2007 | Lakewood HV 18-c Floor / Box Fan
Smeg FAB28 Logo
369 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Charles T Nevin
Charles T Nevin
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
