Question about Nintendo Wii Console
Our sensor bar was cut so we bought a wireless sensor bar, it worked fine on our tv we had because we sit it on top. Now we have purchased a flat screen tv and have to sit it at bottom of tv now there is a delay in A button which causes problems in our fitness program we have. We tried to purchase another wired sensor bar but cannot find one. Please help
    Master:
  • 344 Answers
That isn't a problem with the sensor bar. All the sensor bar is a light emitter, it has a series of infared LED's inside at varying angles. It seems that the problem lies within the radio interference between your WIii more and the Wii. Try moving your Wii away from the TV and maybe even changing the batteries in the Wii mote.
Posted on Mar 28, 2011
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
I just purchased Cabelas dangerous hunts 2001 for my xbox 360 console..... I cannot get the gun to sync with my xbox....Please help!
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook.http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Jan 08, 2011 | Activision Cabela's Dangerous Hunts 2011...
Hi, I own a coby 32inch flat screen, it cuts off the score of all fox football games and I really need to see the score, even in the mode with two bars on the side it cuts off
bought a coby tftv 2425, had a uverse remote that was set to my old zenith, it shut the tv off! The code is1357. It worked on both the sets I bought. Bettter to be lucky than talented!
Dec 13, 2010 | Coby TFTV1923 19 in. LCD TV
Using the Wii Wheel, uncontrollable
you might have a bad wii remote, because the wii wheel is just a case for the remote to sit in. try playing it without the wheel and see if that works. if you dont have any luck, you need a new wii remote.
Jan 13, 2010 | Nintendo Mario Kart (Wii) for Wii
Wireless sensor bar needs setting up
http://www.nintendo.com/consumer/systems/wii/en_na/settingsSensorBar.jsp
The link above will show you how to set up a sensor bar
Bless you son for saying it's wireless lol :)
I hope this helps
Nov 13, 2008 | Nintendo Wii Console
Wii remote hand not showing up on screen
on the front of the wii theres a red button you have to keep you finger on that for 5 seconds and try again this has to be done everytime u have to sinc a different device.
May 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
104 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
