I HAVE A SAMSUNG NOTE BOOK IT SAYS IT AS WI-FI BUT I CANT FIND MT CONNECTIVETY TO SET IT UP
    Master:
  • 325 Answers
Go to http://www.2pages.co.uk
bottom middle theres an orange link (configuring wireless connection)
may have exactly what you need.
Posted on Mar 28, 2011
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
Nov 22, 2013 | Samsung Cell Phones
My samsung netbook n150 plus will not connect to the wifi
Turn on your computer and locate the Wi-Fi icon.
This is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Oct 31, 2012 | Samsung Computers & Internet
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Wi-fi connected but can not connect to the internet. it says data coverage may be unavailable.
please try resetting your phone enter this code *2767*3855# and open again wi-fi....take note all data saving on your phone well erase because it turns to normal setting or factory setting...
Mar 12, 2011 | Samsung Omnia Pro B7320 Smartphone
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Samsung jet s8000
The basic is: 1. On your home screen, click on the bottom right "menu" button. 2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings" 3. Click on "application settings" 4. Click on "Browser profiles" 5. At the bottom right you should see: "Search for wi-fi". Click on it. 6. It will now search for your home wi-fi network. 7. Once it find your network, click on it and enter your security details. 8. Now you network is listed as part of the Browser profiles. 9. Now you can select your wi-fe network as your default browser profile.
Now when you open the browser it will try to conect to your wifi to start browsing.
Enjoy :) Ed
Sep 19, 2009 | Samsung Jet S8000 Cell Phone
I cant connect my note book pc hp to bluetoth for networking
o lisn u should install a new bluetooth just for te system to recognise urs and it will work just give it a try
Jul 02, 2009 | HP NB199UA Pavilion Notebook
Samsung sch-i730 cant access wi-fi
To acces the internet have you tried:
START
PROGRAMS
INTERNET EXPLORER
For Wi-Fi:
START
SETTINGS
Wi-Fi
Tap red bar to switch from Wi-Fi Disable to Wi-Fi Enabled.
Apr 10, 2009 | Samsung SCH-i730 Pocket PC
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
