Question about Dishwashers
I have an Electrolux ESL 4143 integrated slimline dishwasher. When I press the start button - the lights on the options do not flash or switch on when I select a cycle. Is there a reason for this? Is there a reset option not published on FIXYA or online ?
  • 57 Answers
Assuming that power is being supplied to the unit. Unplug door switch. If display comes on. Replace switch.
Posted on Mar 28, 2011
  • nickmof Mar 28, 2011
    I checked power - seems fine - tried in other plugs to be certain - same thing. I also know power is working because I can press some buttons together and other lights come on.
    I have no idea where the door switch is to "unplug it" . Just found out am still in warranty so going to get a service agent out to check it out.
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
Dec 02, 2013 | Electrolux Dishwashers
Electrolux esl 6226 not working beeping sound and light flashing
Hello Eamonn, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 12, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
436 people viewed this question
Top Dishwashers Experts
