Question about Linksys WRT160N Wireless Router
I tried to set up my iPad2 to connect to my Linksys Wireless-N Broadband Router (Model No. WRT160N) using the password that I set 3 years ago. I couldn't get it work after trying the password with upper and lower cases combinations. I am quite sure my password is correct becase I noted it on a paper and kept it safely. I could not figure out what went wrong. Can somebody please help? Can I change my router passwordo a new one so that I can use it for iPad2? How can I make change to current password? Will this affect the wireless connection between the router and my existing PCs? Regards, John Sieu (Hong Kong)
    Sergeant:
  • 212 Answers
Make sure you have set up the security on the router to match the type that can be handled by the ipad.
If you are using WPA2 AES encryption for example, you may want to verify that the ipad2 can connect to it. This could be the case with any type of encryption. If you are using WEP make sure you are choosing the correct bit level (64 bit vs. 128 bit etc)
I would recommend trying WPA TKIP encryption, it is pretty secure and usually pretty universally accepted.
Posted on Mar 28, 2011
Have a Linksys Wireless router Model WRT160N Security is set at WPA2 Personal i can not get my new iPAD to connect when i diasable Security it connects I am looking for a suggestion I also need...
@joea1956
Try the following:
1. If you want WPA2 encryption on your router, (which also have higher security and compatibility issues with wireless cards), you could try WPA2-TKIP (which is standard encryption and made compatible for all wireless cards) or WPA2-AES (for specific wireless cards that are unable to connect to TKIP encryption)
2. If Step 1 won't work, try to lower your security encryption to WPA-PSK (either TKIP or AES) and try again. If this works, your IPAD2's wireless card doesn't support WPA2 encryption yet.
If all of the above fails, I do not recommend WEP since it's easily cracked (for advanced users) but you could try it as a last resort.
Good luck.
Sep 08, 2011 | Linksys WRT160N Wireless Router
Lost wireless connection
  1. Follow these steps to configure Linksys WRT160N wireless router.
    Open Internet Explorer, it does not matter if you see error message such as "The page can not be displayed" . now erase everything on the address bar and type in this IP address: 192.168.1.1 or the full address: http://192.168.1.1
    This is the default IP address for the router set by Linksys.
  2. 2 Hit the Enter key on your keyboard to connect to the router's web admin control panel. You will be prompted a login window for the username and password: the default admin username is "admin" and the default admin password is "password". If you can't connect to this admin control panel, you will need to change the IP address on your modem, maybe your modem is using the same IP 192.168.1.1 also, just unplug the router from your modem, and hook up your computer directly to the modem and fire up the web browser and enter the IP 192.168.1.1 and follow the on screen direction to get in.
  3. 3 It will then ask you to change password, then you make up a password that is meaningful for you to remember. You will need to write down the username and password for future reference because I am sure you will forget. You will need to reset the router if you forget the router password, and that will erase everything saved inside the router setting.
  4. 4 After successfully login, you will be in the Basic Setup of your Linksys WRT160 wireless router. You also might need to clone the Mac Address if you are using Cable Broadband (Comcast), to do this go to Mac address clone -> Enable, then clone my computers Mac.
  5. 5 If you are using Verizon, you might need to change the Internet Connection Type to PPPoE and enter your username and password that is created by Verizon.
  6. 6 I think many of you concern more on the Wireless secrutiy. Click the Wireless tab and enable the wireless security, you will need to choose a type of security encryption, WEP is weaker, you will need to type 10 characters for the pass code. The WPA or WPA2 is much stronger that it takes passphrase. For more security on wireless connection, you can also try to use MAC authentication, each of your laptop or wireless card has unique MAC address, you find out the MAC address on your laptop then enter it into your router so only this laptop can have access to the wireless connection.
Jan 25, 2011 | Linksys WRT160N Wireless Router
Compatibility with high speed ADSL2 Broadband
Yes, Linksys WRT160N is 100% compatible with ADSL2. Linksys WRT160N is a Broadband router.
you will not be able to use the linksys WRT160N, as an ADSL2 modem router. you should be using an ADSL2 Modem separately and connect the cable from the modem to the Linksys WRT160N. Hope this clarify the doubt.
Apr 02, 2010 | Linksys WRT160N Wireless Router
Linksys WRT160n V2 Wireless-N broadband router was working not long ago then just.. currently all lights are blinking i dunno what wrong please help?
Try hard resetting it for 1 minute to 2 minutes ; press and hold the reset button properly for that certain period and after that powercycle it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
Will not allow me to connect using an ipod touch.
My IPaq wireless has an icon that lets me log into other networks by just selecting them and putting in the password or no password if it's an open network.
I Googled the Ipod touch instructions and found a MAC blogger with the specific instructions here http://mac.blorge.com/2008/07/14/wi-fi-setup-how-do-i-access-the-internet-with-my-ipod-touch/
If you can't login because you don't see the router, try logging into the router from a computer connected to it and make sure the wireless is turned on and broadcasting an SSID. If you have a WEP password set, you will be able to read it under the Wireless Basic Wireless Settings tab. If you need specific help with the WRT, you may visit the Linksys site. Here's a link to connecting your wireless device to a Linksys product http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=20947
or, here's a manual where you can start at page 13 http://downloads.linksysbycisco.com/downloads/userguide/WRT160N_V10_UG_A-WEB,0.pdf
Carl
Jan 01, 2010 | Linksys WRT160N Wireless Router
Hi i hope you can help me i nead to know how to reset the pass word for a linksys wireless n broadband router model wrt160n v2 my laptop had a virrious and i lost everything i do not remember the pass word...
Ok, on the bottom of the router there is a reset button you need something small to push in. Once you press this the router will go back to fatory settings and you can set it up again with a new password and settings.
Nov 05, 2009 | Linksys WRT160N Wireless Router
Speedstream 5100 connected to dsl and linksys wrt160n router - very slow internet speed after power is turned off and then restored
Try to Upgrade the firmware of the router.Go to http://www.linksysbycisco.com/US/en/support Enter the model no wrt160n. Click on get downloads,select the version of your router and download the firmware.Then open 192.168.1.1 in your internet explorer,it will ask for userame and password.Leave the username blank and in password type admin and press enter.Click on administration and under that click on firmware upgrade.Browse and select the downloaded firmware file and upgrade the firmware.
Apr 29, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless-G router
I’m sorry to tell you what the only way is the hard way.
Find and press the reset button on the back of the router.
Now - hopefully you remember how you set up the router previously, or you have to do this at the same time in all the computers on the wireless network.
NOTE. Do use cable between the router and the pc you perform setup with.....
Please vote if this help you.
Nov 29, 2008 | Linksys Wireless-G Broadband Router
Linksys wrt160n wireless router
how can i connect my router so that i can use my laptop
Sep 27, 2008 | Linksys WRT160N Wireless Router
Do i need a modem for my linksys WRT160N Broadband router of enable to connect to my dsl, or can i connect directly my dsl cable to WRT160N Broadband router. Thanks in advance
Greetings,
You need to have a separate DSL modem
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
960 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
