Question about Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier
The string inside my ionic breeeze quadra is broken. Is it possible to fix it
Not so fast with the screwing part. Go to a music store, buy the G string wire(008)gauge- at least 41 inches long- for a guitar.
If you have a digital camera make a video/pics history of your dis-assembly steps.
Remove the ozone eliminator-by pulling it off the tower.
Start with the base 4 screws, followed by the 2 collar screws at the base.
NOTICE that there is a space between the two halves at the bottom. I paid NO attention to this space-boy did I ever try to snugly close that one before I looked at another one to see that this separation is there for a reason.
Next: remove the "TINY"12 screws - 6 on the front/back side of the units ribs-look for these.
Take pics of each step. You will be happy you did this.
Store all of these diff. screws in separate jars.
Open the unit now like a wallet. Notice that the sloped top control button/light module can now be removed. See those 2 black square plastic covers-they hide a spring and an upside down W shaped wire holder. The broken wire can now be removed. If you are lucky, you may be able to to twist your new wire-after pushing it through the cleaning bead -with the one going down to the bottom module. Mine was too brittle and broke apart as soon as I touched it.
Remember: The 2 wires you see are just one 41 inch long 008 gauge guitar string.
They thread through a signal contact bracket at the bottom of the unit that is activated by the breaking of the wire to turn the unit OFF. Getting to this bracket is somewhat difficult and requires patience. Take a lot of pics to be able to reassemble the S 1637. I pulled the 41 inch long string under this signal bracket, evened off the ends, moved the top module down 2 inches and twisted the ends around the W shaped bracket that compresses the spring.
Honestly, I had to adjust the spring two times because I left off the cleaning bead. Now just reverse the steps and you got your unit working. The new string seems to push a lot more air.
Before you replace all of the screws, fold the unit together, insert the blades , put 2 sets of veggy rubber bands around the top and bottom and plug in/turn it on. Mine works now better than new. Did I mention that I had to do 2. The second was done in 2 hours.
Good luck.
totrosko@yahoo.com
Posted on May 16, 2011
Hi, I have the ionic breeze germicidal air purifier floor model. One of the wires inside has broken. Can I get this fixed?. Thanks for any help you can give. Joyce Turner
Joyce, according to Sharper Image, if you purchased it online from Sharper Image after 2008, they will assist you with the repair. Call Customer Service 877-714-7444 . If that is not the case, you can either return it to the place of purchase for repair or take it to a small appliance repair shop,
Apr 21, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
I HAVE 2 IONIC BREEZE QUADRA. FIRST HAD PROBLEM WITH 1, NOW THE SECOND ONE HAS SAME PROBLEM. HAVE CLEANED AND DRIED THOROUGHLY THE BARS AND FILTER, AND CLEANED REST OF WIRES WITH BRUSH. WHEN I TURN ON I...
If none of the hi voltage grid wires have broken then check to be sure grid wires are truly cleaned.
If not cleaned in a while like every 2 weeks they will have carbon build on them. And from my experiences with cleaning them is the build looks similar to the color of the wire. Try some qtips dipped in alcohol or cotton balls. The build comes off like flaking metal. Also be very tender with these wires they break fairly easy. When done cleaning turn upside down and back so beads can scrape up and down on wires. Also you do know once clean the parts especially the big collection bars they need to dry for at leased 24 hours before ever powering unit back on. Hope this helps.
Dec 13, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
I have an ionic breeze quadra. When I turn it on,
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station. Good luck!
Feb 08, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the quadra up and down. Can it be replaced and how? Thanks.
You're probably screwed...
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 02, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
How do you reset a Quadra ,Ionic Breeze
Hi.
This appliance simply resets by disconnecting the power cord for five minutes. The control board does not include battery.
If the model was manufactured before 2007, pleas read below.
Ionic Breeze Concerns
Regards.
Ginko.
Nov 14, 2009 | Sharper Image Professional Plus Ionic...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Broken Wire inside unit. Looking to have it repaired or purchase part.
You're probably screwed....
May 21, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Is my Ionic Breeze Quadra hopelessly broken and beyond repair?
This unit can be replaced on ebay for around $45.00 which is under any labor cost to repair the unit you currently have. You can always post your unit for sale on ebay for parts.
Feb 19, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier Logo
198 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
