Question about Compaq Heatsink CPU Heatsink & Fan
Am using an mPAQ model:M66SE laptop. it heats up very much and after few minutes it hugs up.until i restart and wait few some minutes and cools. what will i do. the heat sink on top of the south bridge is very host and also the one of the processor.
  • 656 Answers
Remove your heat sink then clean the surface of the heat sink with clen cloth apply athin layer of heatsink compund and fix the heat sink tightly if the heatsink is dried or worn out the heatsink gets heated up also check the fan is working
Posted on Mar 28, 2011
    Problem Solver:
  • 10 Answers
Hgkh
Posted on May 15, 2012
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
My fan will not shut off when I shut the engine off
How long does it run? some cars will run the fan for a few minutes to ensure that too much heat does not build up under the hood. Wait for 5 minutes and see if it is still running when the engine is off. If it is you may have a bad temperature sensor. Does the engine temperature gauge work properly?
May 31, 2015 | 2001 Dodge Caravan
4 stroke tiller starts and runs great for ten minutes and shuts off. No sputtering or nothing... just quits. Troybuilt
will it restart immediately or do you have to wait for awhile? if it restarts then check the fuel flow from the fuel tank to the carburetor. if it doesn't and you have to wait then check the ignition module. as the unit gets hot the module heats it stops working and as it cools off it works until it heats up again
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 23, 2013 | Garden
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
Driver problem
DriversGuide, good place to start, Get Chipset, then Lan install in that order...Run os validate then let Windows find the rest....
May 15, 2012 | Computers & Internet
My inspiron 1525 will shut down every 15mins or so. i don't what is wrong with it.
Most likely, if you have not set the power settings in the control panel to do this, you have a heat problem.
This can be tested by turning on the computer and using it until it freezes or turns off. Wait a few minutes and if it turns on again, it is most likely heat. Check to see if the cooling fan is running. Also, with canned air, blow out the dirt that accumulates in the case.
Jul 18, 2010 | Dell Inspiron 1525 Notebook
My dell dimension 8250 'Sound Blaster Live' will work for a few minutes, then shuts off. If I wait, it comes back again, etc. What's wrong? Thanks.
Thats your system restarting every small minute then the problem lies on your processor or probably your processor fan that is blowing air to your processor stops working and that can cause it not be ok after a short time it will be over heated and have to cut off and restart again what you will have to do is to change the processor fan or probably add a cooling paste on the processor cooling sink or if that persist change the processor.
Mar 06, 2010 | Dell Dimension 8250 PC Desktop
Sudden shut down
You need to clean it out with some compressed air.
Make sure the laptop is turned off of course.
If you still have heating issues, then you'll need to take it apart and put a new layer of thermal paste on the heat sink / cpu.
Best of luck!
Jun 18, 2009 | Computers & Internet
Dryer shuts off after minutes, until cools down
have you cleaned the filters on it. it might be the thermostat if you have. or checked the outlet pipe for excess fluff.
Mar 26, 2009 | Dryers
Compaq Heatsink CPU Heatsink & Fan Logo
169 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
