Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
Freezer will only work if the dial is set to no.4 anything lower and it starts to defrost plus warning light only works on super freeze.
    Scholar:
  • 116 Answers
HI you need a new thermostat, the thermostat is sticking. Change it out will fix your problem
Sean
Posted on Mar 28, 2011
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
Why has my freezer stoped freezing. it is cold inside and the red warning light is on
The defrost heat element has failed or the fan unit has failed, either way it is easly diognosed and not too costly if you pick the right repairer.
If you turn the unit off for 2 days and defrost it total, then turn it back on, should work fine for 4-5 days then return to problem again, confirming my report, you can then tell repairer you are not stupid and hence, not get ripped off.....Russ
Aug 28, 2011 | Zanussi ZBF6124 Freezer
The temperature keeps on rising. everything inside is melting. does not freeze anything. fan and light is working.
Turn it off, defrost it for a couple of days """""with the door open""""", restart it with door closed and see if it starts freezing again after about 2-3 hours, if so, then the draw unit works, that indicates the defrost cycle needs to be reset or one of the defrost elements has failed causing the rest no to do anything. Any probs call me on 08 9523 0552 Russ
Feb 27, 2011 | True 31 cu. ft. / 878 liter Upright...
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Need correct setting for 30 yr old upright Kenmore freezer
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
Feb 17, 2009 | Frigidaire Upright Freezer FFU12F2H
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Freezers Logo
148 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
