Question about Acer Aspire 3680 Laptop
I have an acer laptop and the plug is not making a connection except when it is turned in an upward position. Otherwise it appears to be connected only to run down
This is an Acer Aspire 3680-2682 laptop computer.
My father bought a second hand laptop from canada . when i started it ask for a password means somebody made the password and gives hint as white . i tried a lot but password doesnt open. my father also not got any password so there is no use without password.what should i do ??
Posted on Aug 07, 2008
Problem with wireless and wifi connection Acer Aspire model v5-431 note book
Is the adapter turned on? That means the software, hardware, and device switch must all be in the ON position. Otherwise, it won't work. Try resetting your Wi-Fi Adapter in Device Manager.
Dec 14, 2013 | Acer Aspire 5100 Notebook
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
My Acer 240 screen won't work it appears to be working otherwise
Connect a monitor to the video output, if picture is okay the problem is in the inverter board located under the laptop screen, or the backlight has failed, now if the monitor shows the same symptoms the problem is in the video card ic.
Sep 02, 2012 | Acer TravelMate 240 Notebook
How do I connect acer aspire to tv
You will need an HDMI cable. Connect the laptop to the television and on the television, you will need to change the "Source Input" setting. Select the HDMI setting on the television and everything that you see on your laptop will appear on the television.
Oct 23, 2011 | Acer Aspire One PC Notebook
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Hello, I cannot connect my ACER ASPIRE 1640 to an external monitor. I only have a predeterminated monitor as configuration option. Please, help me. Thank you Luca.
Alright 1) Turn your laptop off, connect the cables to your external monitor such as a t.v, monitor screen, through your apropriate source such as HDMI, VGA, or S-vdieo which ever one you are connecting it to. Turn your external Monitor on, and if it is a t.v make sure it's the the correct input otherwise it won't work. Then Turn your computer on, once your computer is in the Operating system and completly loaded, Then you want to press the FN button + the F5 button to swtich your display from your laptop to your external screen. There is a little Icon that appears on the screen that lets you know that it is switching either it's duplicating, to your external monitor only or back to your laptop screen, your screen may go blank for a second once your made your choise. Then you should be god to go.
2) If it doesnt work, you might want to try loading your computer first and then plugging in the cables and turning your tv on.
3) If that doesn't work, then maybe your FN button is disabled, and you need to enable it in acer windows mobility aplication. If you have question let me know.
Feb 06, 2011 | Acer Aspire 5100-3357 Notebook
Bought an acer laptop for daugher cant get it connected to the internet via our router. what do i do .. the satellite button does not turn blue cannot connect any info would help ..
There is a switch on the acers normally in the front of the laptop that controls the wifi. All of them have it most likely on the left side front make sure it is turned to the right or on position.
Dec 29, 2009 | Acer Aspire 5610-4648 Notebook
Mcafee
McAfee has controls that can lock you out of the internet. Are you trying to connect via wi-fi or ethernet cable? If it is wi-fi, try disabling McAfee, connect to your wi-fi then turn it back on. You'll need to make an exception for that connection. If wired, disable McAfee, make an exception for port 80, 8080, 23.
Apr 18, 2009 | Acer Computers & Internet
Cannot connect to internet from acer laptop but am connected to a wireless network, what am I not doing?
Check if your LAN card is enable:
Go to Start and click on Control Panel.
2) Control Panel window will appear. Double click on Network Connections.
3) Network Connections window will appear. Right click Local Area Connection.
If the connection is currently enabled, the first option in this menu will be Disable. Otherwise, the option will be Enable.
Click on the Enable/Disable option to enable/disable your network connection.
Jul 26, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
