Question about Watches
Instructions to set time on kenko watch - Watches
WHERE CAN I FIND THE MANUAL FOR THE ARMITRON 40/8284 PRO SPORT WATCH?
hi Robert.
i can not find a manual for this watch,but if you go to this link it should show you step by step on how to set it up.
its not showing your model number so not sure how good it will be to you.
if another window opens on the page just close the popup window down.
Instructions to Set the Time on an Armitron Pro Sports Watch
or try this.
How do you set an armitron pro sport watch? Press the "Mode" button repeatedly until the time display appears on the watch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
Instructions to Set the Time on an Armitron Pro Sports Watch ...
https://www.livestrong.com/.../247211-instructions-to-set-the-time-on-an-armitron-pro-s... Search for: How do you set an armitron pro sport watch?
or read up on this link.
MANUAL FOR THE ARMITRON 40 8284 PRO SPORT WATCH Google Search
Nov 29, 2017 | Armitron Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How to set the indian standard time in this watch
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
If you cannot find the caliber number for your watch, enter the example number (E810) and you will find instructions for settiing th local time.
Dec 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
I have a Kenko KK-613D LCD clock which came inside a bathroom cabinet, but no instructions, can you help please.
BP Digital Clock Instructions (translated from French)
Manual:
1. To set alarm in normal mode press M twice.
Press S and D to set then press M to exit.
2. ADJUSTING the Time and Date:
Press M three times to go to setup mode
Press S to go on setting the minutes and press D for adjustment
Press S again to adjust schedules and press D to set
Press S again to adjust the date and press D to set
Press S again to adjust the month and press D to set
Press S again to adjust the week and press D to set
Then press M to return to normal. The previous settings are automatically saved.
Press D to display the date.
Oct 29, 2010 | Watches
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 | Watches
A friend has a talking watch & has lost
Unfortunately there are no available instruction downloads for Marcel Drucker talking watches. Use this link to get in touch with them and request instruction manual: http://www.marcelwatch.com/category_s/23.htm Rate me, plz.
Feb 26, 2010 | Watches
Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
Aug 05, 2009 | Seiko SGF204 Wrist Watch
Instructions
i have a CL-5073
to set time:
HOLD "Set" for 3 seconds
then use "Mode" to browse through option
When you get the time setting hit "St/Sp" to set the time
When you're done press "Set"
hope this helps
May 03, 2008 | Columbia All Sport Digital watch
Watches Logo
113 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
