Reset factory setting for Canon ir3300 copier canon photocopiers ir 3300 E602-0003
123Angela456
SOURCE: Canon IR3300 showing the error code E000602-0003
Nevermind. I researched the error code and fixed the problem. Thanks anyways.
Posted on Jan 03, 2008
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: i want canon ir3300 multifunction printer drivers for windows xp
i want ir3300 cmputer drivers
Posted on Jun 04, 2010
SOURCE: How to reset factory setting for Canon ir3300 copier?
how to clear all settings and password , to return machine normal .
Posted on Jun 22, 2010
Default Id & Password ir 3300 canon
I suggest you read the manual book canon IR3300.
Manual book, you can download here
Canon imageRUNNER 2200_2800_3300 Reference Guide
For additional materials, the solution to the problem IR3300 ID & password, you can read here
I hope this information helps
Nov 15, 2011 | Canon Office Equipment & Supplies
How can i save scaned datas in my canon ir3300 photocopier
what is the problem in imagerunner3300 with the error code No. E191?
Sep 03, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I required Canon Photocopier IR3300 driver
Hi, try this link for your driver:
http://www.givemefile.net/drivers/_xerox_and_ifis/canon/ir-3300.html
Aug 07, 2010 | Computers & Internet
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Need a hard disk recovery software for canon ir3300
hi i am form India i have canon ir 3300 i am getting error for E602-003 pls no technician
Jul 08, 2009 | Canon Office Equipment & Supplies
Canon ir3300 or 405 better
Definitely go with the 3300 (if you haven't already). It's one of the best B&W copiers Canon has ever produced. The 3300s still sold as refurbs by Canon in the US so parts will be around for them over there for quite a while yet.
Oct 08, 2008 | Canon Office Equipment & Supplies
116 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
