I replaced the backup batteries for my ihome ip88 and then it does not work any more. i replaced the backup batteries when the batteries are empty and the clock do not show anything. now my ihome ip88 never turn on. the ac power is not useful. does somebody can help me?
techman
  • 3130 Answers
SOURCE: RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Posted on Mar 24, 2006
shaggyrat
  • 1224 Answers
SOURCE: T30 2366 8GA After removing AC Adaptor battery icon shows Charging and working on AC
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
Posted on May 26, 2008
  • 37 Answers
SOURCE: Battery Backup Outlets Not Working
well it could be your ups hardware is already fualty.. either u replace a new ups of ask a service if your worries is abt the cost you can ask mi if you are interested price you can neigotiate
Posted on Mar 24, 2009
greg_margo
  • 1959 Answers
SOURCE: 97 aurora AC not working
GM products have a safety feature which shuts down compressors is they run too low on refrigerant. Honestly surprised you were able to fill the system with refrigerant since the compressor would have shut off. The best way to reset the compressor is to disconnect the negative battery cable for 15 min. After reconnecting, the compressor should function again assuming there's enough R-134A in it. If there's not, turn the AC to MAX and add the refrigerant. At this point, the system should actually **** the can dry. Hope this helps with your AC problem. All the best!
Greg
Posted on May 20, 2009
  • 164 Answers
SOURCE: Main Battery Power
It cannot switched the batteries. The backup one is a small internal battery just to keep the CMOS with data. That's it.
If you main battery is not charging or when unplugged won't power on, the is likely the main battery is defective, or the charging circuitry of it is failing.
Best regards,
Posted on Jul 24, 2009
I have no elitisity how do I get my ihome ip90 to work I already put in 2 aa battiers and it still doesn't work please help me
The battery backup only keeps your settings. It is not sufficient to run the display or other functions. You will need to plug in this clock to actually use it.
Oct 30, 2012 | Office Equipment & Supplies
My iHome iP43's volume stopped working when i replaced the dead +zero brand batteries with unused energizer brand batteries...what happened
Sorry! we have different skill levels and don't always include the specific problem you have encountered. It means we read your question but may not know the answer.
Aug 27, 2012 | iHome IP43 Desktop Clock Radio - Apple...
My iHome keeps resetting the date, alarms, presets... everything! I fix it to how I had it, then two days later it resets itself again to January first, 2008..
Check that the power supply cable isn't broken. It could turn itself on and off by itself. If it has a battery backup use that.
Jun 05, 2011 | iHome Clock Clock Radio for iPhone iPod...
How do I program my remote for the ihome ... I lost the manual and I cant find it.
According to the manual the iHome IP90 line does not have a programmable remote. Have you checked the battery in the remote? It requires a CR2025 battery. The remote also has a 30ft. range, not sure if you are trying it at a further distance.
In any case, first thing I would do is to get a replacement CR2025 battery and give that a shot. If that doesn't work then the remote might be defective.
May 06, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
Hi I have an iHome alarm clock/radio that has an ejectable outlet for the iPhone/iPod/ etc and after one drop to the floor, the piece that reads iHome broke off and the ejecting piece does not push out by...
sadly this devices are no longer sold
you should try to find a damaged iHome and use for replacements or find a used one to replace your actual device
ihave an iHome too, and i had made some tricks to keep it working
Mar 22, 2011 | Audio Players & Recorders
My iHome is charging my iPod but won't do anything else. The clock face isn't working which means I have no alarm clock.
I just had this same problem, I removed the battery and my IHome now works
I hope this helps
Feb 25, 2011 | Audio Players & Recorders
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Open Questions:
185 people viewed this question
 Grubhead
Grubhead
