Question about Energizer 1 Hour Battery Charger With AAAAA Batteries (CH1HRWB4)
I have been given an Energizer CH1HR-ANZ Nickel metal hydride battery charger. I have trided to charge some Nickel metal hydride batteries of a differernt brand but when I plug it in ther charging indicator LEDs flash on and off. Any ideas what this means?
4 Suggested Answers
  • 8 Answers
SOURCE: Energizer CHDC charger suddenly not indicating if charging or not
It sounds like the PC Board which provides the circuitry for the Charger's indicating light is malfuntioning. If you have a DC volt-meter, you can check the Charger's output voltage, and then the Battery voltage to determine if your charger is functioning.
Hint: If the Charger has an output voltage, but the Battery's voltage is less than its rated voltage... it's time for a new battery.
Posted on Mar 23, 2009
SOURCE: i have an energizer CHCC-UK battery charger. As
wHEN THE GREEN LIGHTS COME ON IT TAKES ABOUT 12 HOURS TO FULLY CHARGE THE BATTERIES. WWHEN CHARGED THE LIGHTS GO OUT. Ken13
Posted on Jan 02, 2010
heatman101
  • 43501 Answers
SOURCE: Energizer Digital Camera Battery (ER-D120)-
The battery is either too hot or too cold....if it was just used then give it time to cool down before trying to charge...
If the battery is at room temperature and you are still getting the fault code then the battery is shorted or open internally.
If the battery has an internal fault it is not easily repairable and you should just recycle it and buy a new battery.
heatman101
Posted on Aug 11, 2011
How to order a lithium ni-cd rechargeable battery for a Mansfield Dual Head Drill Model 11-707? Please help and advise.
Battery is either ni-cad (nickel cadmium), Ni-mh (nickel metal hydride) or Li (lithium ion)
I do not know what the original battery was. You may be able to obtain a Li version but may need a different charger as charging rates for each type vary.
Dec 31, 2017 | Mansfield Drills
Mine has broken where can I get a replacement
All About Battery Chargers - Battery University
batteryuniversity.com/learn/article/all_about_chargers
Battery UniversityOct 16, 2015 - Figure 1: Battery and charger must go together like horse and carriage.... charge time but there are limitations as to how fast a battery can be charged. .....There are universal lithium chargers available but these only charge at .... i want acharger to charge my lead acid batteries(12V-26Ah) within 6hours.
[PDF]Energizer Rechargeable Batteries and Chargers: Frequently ...
data.energizer.com/PDFs/Rechargeable_FAQ.pdf
Can I use another manufacturer's charger to charge my Energizer® NiMH Rechargeable batteries? 18. ... 22 Why are rechargeable batteries 1 2 Volts? 22. ...When not in use, nickel metal hydride batteries will lose 20% to 50% of their chargewithin six months due to ... Energizer offers several universal voltage chargers.
Dec 02, 2015 | Drills
I have a motorola radius gp300. the charger flashes red when charging
It really depends on the charger. Does it do this for your brand-new batteries, or just the batteries that are more than 2 years old and, therefore, need to be replaced? If it's happening to a brand-new battery, then maybe you're trying to use a nickel-cadmium battery charger for lithium-ion batteries or for nickel-metal hydride batteries, and you're dealing with a chemistry problem which requires Ni-CD batteries or which requires a newer charger.
Mar 30, 2012 | Motorola Radio Communications
I have an Energizer Model CHDC7 battery charger for AA/AAA batteries. I'm not sure how to use it. Specifically, when batteries are inserted and plugged in, it displays flashing green lights over all...
Nickel-Metal Hydride (NiMH) batteries are usually charged in pairs in consumer chargers. The CHDC7 can charge two or four batteries at a time. Their position in the charger is important (see the link at the end of this note). Each battery has a separate pair of green LEDs. There are no other LEDs on this charger. The LEDs light up to show the state of charge. Flashing means it is charging. Solid means it has reached that level of charge (ie, 1 LED = half charged, 2 LEDs = fully charged). The batteries will get warm but not uncomfortably so. After some practice you will be able to tell if they are getting too hot (which may signal a worn-out battery which should then be replaced). Like all rechargeable batteries, NiMH batteries have a finite life (measured in number of times they've been discharged and recharged). IMHO, they should also be used and charged in matched pairs. I mark them when I take them out of the box and keep them paired in use and in charging for maximum life. Yes, the devices that use 3 batteries are a pain to deal with. LOL. All details can be found on this Energiser data sheet: http://data.energizer.com/PDFs/chdc7_instructions_english.pdf
P.S. The CHDC7 remains open for charging. Closing it for storage is optional but minimizes the space it takes up.
Jul 30, 2011 | Vacuums
I NEED THE BATTERY
you can get the battery from the below website,,,,please click the link below to get a new one....
http://www.amazon.com/Energizer-ER-P240-Nickel-metal-Hydride-Cordless/dp/B00006JM6J/ref=dp_cp_ob_e_title_0
thank you
Sep 24, 2010 | Motorola Mobility MD700 Cordless Expansion...
How do i know if there is a problem with my double a rechargeable batteries
Although it would be helpful knowing what kind of rechargeable batteries these are, presuming they are Nickel-metal hydride, you can try putting them in a freezer for several hours and then recharge them. Sometimes this jump starts the electrochemistry.
Jun 24, 2010 | Energizer Rechargable Battery with Charger
I've been using Olympus 550 UZ camera for over a year now. I am facing problem with the life of battery though. Tried Energizer and Duracel batteries. 10-15photos and the battery is drained down. Is there...
Switch from alkaline batteries to pre-charged Nickel Metal-hydride (NiMH).
My best experience is with these batteries:
#1. RayoVac (pre-charged)
#2. Kodak (pre-charged)
#3 Energizer (rechargeable)
Find them at WalMart or online
"pre-charged" are new technology rechargeable batteries. They are GREAT! They outlast alkaline at least 15 times per charge.
Sep 28, 2009 | Olympus SP-550 UZ Digital Camera
Well i tried to take a picture and i took it and then it turned off once i took the picture
Sounds like the batteries.
Digital cameras are noteably, very demanding power suckers.
If they don't have brand new batteries, they shut off.
They requre top brand (Energizer or Duracell) batteries, and once they are used for even a short time; they will not be enough either.
(Dont' throw them out though, other less demanding things like Remote controlls will gladly use them for years)
The best bet is to use Rechargeable batteries, or have a $100/month budget for duracells.
Statistics you will need to look for in Rechargeable batteries are:
Type; Nickel Cadmium (Ni-Cd) or Nickel Metal Hydride (NiMH)
The Metal Hydride rechargeable battery is best since it charges faster and retains it charge longer, the old fashioned Nickel Cadmium battery used to be the best, but not any longer.
Rating: 900mAh; 1800mAh; 2200mAh; others not mentioned.
Unimportant note: The mAh means Milli Amphere Hours, which means how much power the battery cell will hold when fully charged. It is measured in Ampheres (Amps) per Hour, or in this case Milliamperes (1/1000 of an amp), but that's not important to know; all rechargeable batteries are rated by this number.
The number of mAh's you want are about 1000 or more,
Generally it's the more mAh's you have the more you can take pictures. Such as 900mAh will get about 50 to 250 pictures, but 1800mAh will get you twice as much.
Last note on Rechargable batteries: Only use a LiMH charger for LiMH batteries, and use a NiCd Charger for NiCd batteries.
If a charger dosn't say what type of batteiries it charges, it's the old fashioned NiCd (Nickel Cadmium) from the 1900's when that was the only type of rechageable battery.
Good luck with your Digital Camera.
Jul 28, 2009 | Kodak EasyShare CD40 Digital Camera
Mar 11, 2009 | Energizer Rechargable Battery with Charger
Batteries always low
If you're using regular alkaline batteries that?s fairly common. If you want longer life most people purchase rechargeable nickel-metal hydride batteries and a charger. Depending on the camera you?ll get 40 or more flash images out of a charging. I have two sets, one in the camera and one in the charger. Expect to pay about $5 to $10 for a set of four and around $10 or $20 for a charger, make sure its for nickel-metal hydride batteries and not the old style nickel-cadmium. Good luck and don?t forget to rate this post.
Mar 03, 2007 | Polaroid i832 Digital Camera
Energizer 1 Hour Battery Charger With AAAAA Batteries (CH1HRWB4) Logo
406 people viewed this question
Top Energizer Cameras Experts
Jaye t rock
Arthur Cowgill
Level 1 Expert
Are you an Energizer Camera Expert? Answer questions, earn points and help others
