Question about Vintage Keeper 250 Plus Wine Cellar
Cooling unit is not working, but the fan is. Do I need to replace the unit or is there something else that can be done. The unit was purchased in 2002. Thanks.
How do u know if the cooling unit is bad
First, look behind the fridge at the bottom. There should be a thermostatically controlled fan that kicks on and off according to the cooling needs of the unit. That fan is what keeps the compressor from overheating and failing. After watching it for a while, if it is not ever turning, and if the compressor is hot to the touch, you need to replace the fan. I've done it - not that big a job. If the fan is working and the unit continues to not cool, you've probably got a bad compressor and it's time to call someone.
Jul 02, 2017 | Refrigerators
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
Not cooling yellow chemical in outside compartment
Any sign of yellow residue on the rear of an RV Fridge means that you require a replacement cooling unit. It is something that can be done by most RV owners. Ive attached a video that will walk you through the install of your cooling unit. The video is by ArctiCold Refrigeration We keep it cold The cooling unit can be purchased aftermarket at Arcticold's online store. www.arcticoldstore.com
Store
Feb 11, 2014 | Dometic RM2852 Refrigerator
Goodman outdoor a/c unit top fan stopped working while the family was away from home and now the compressor will not turn on. Only thing happening when a/c turned on inside is the indoor unit kicks on and...
the fan would need to be changed also it may have over heated the pump. if it has been left for a long time in this way it could of done more damage. you could be luck and that the fan might be telling the unit control its not moving so it will not turn on. but to find this out you will need to replace the fan if the fan has 3 or more wire it would have this feature.
Jun 27, 2017 | Heating & Cooling
Bottom of laptop gets very hot - too hot to put on my lap
Please immediately call sony support, in case your unit is in warranty, they would do an inwarranty repair on your unit. I used to work for sony in 2005, at that time they did not have a policy of giving you a replacement unit in warranty. I do not have any idea now.
Jun 27, 2010 | Sony VAIO VGN-S660/B Notebook
The radiator cooling fan is not working. Upon
assuming fuse and relay are good..no fan should be running when the engine is cool/cold, the only time the fan should be running when it reach over operation temperature which then the fan kick on to bring the temperature back down to it operation temperature. both fan work in sync with one another, addition cooling is needed when the ac is running. when the last time have you replace thermostat and Thermos sensor/switch. I would replace both unit if you have not done so. The thermos/switch will turn the fan on when it reach certain temperature and cut off when it sense the temperature drop in the engine.
Aug 25, 2009 | 1999 Lincoln Town Car
Cooling fan won't stop
yes, there is a t-stat in the circuit that controls that fan. Follow the wiring from the fan and it will lead to the t-stat
Aug 04, 2009 | 1993 Honda Accord
Fan in our Sharp "Comfort Touch thru-wall a/c stopped
Unless the Unit can be cleaned ( you claim it cools?) but not enough. The age of the Unit is not in you Question, the amount of time you got for 100 bucks is pretty good being you purchased a USED UNIT. With the type of use you claim Running 24/7 and about 5 months of cooling - I'd say you never cleaned the Unit from day one - that might cost you about 100 bucks if the unit can be done in the yard by a serviceman. Chemicals can hurt the Unit if not done properly ( and yourself). It sounds to me like you use it for a Business - if so you can purchase one and write it off .
Jul 18, 2009 | Sharp AFR120NX Thru-Wall/Window Air...
Replacing cooling fan clutch????
Hi
Yes you need to replace what is called the Fan Viscous Coupling Unit.
Then swap over the fan blades.
Quite straightforward.
Good luck !
John.
Jan 19, 2009 | 2001 BMW 325
Magic Chef 8 bottle wine cooler model MCWC8DSCT. When turned on light flashes and fan starts to move but doesn't. Sounds like a relay keeps switching off and on. Do you know what the problem is? And which...
I have the same problem as stated with the light flashing and fan tries to rotate. I found by disconnecting the power wires to the cooling unit, the fan rotates. light works and no clicking sound.
I suspect the cooling assembly is defective causing the unit to not work properly.
Does any one have a part number for this part and where I might purchase the cooling unit. RepairClinic.com does not have thhe cooling unit.
Jul 18, 2008 | Refrigerators
Vintage Keeper 250 Plus Wine Cellar Logo
56 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
