Question about Sharp Microwave Ovens
Working but no heat - Sharp Microwave Ovens
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
If it is the type with an "Invertor", they are not user serviceable and should be directed to an authorised repair agent for continued safety, otherwise if conventional;
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 28, 2011
Fan not working on Whirlpool microwave Model MH2175xss1
What do you mean "fan doesn't work"? Magnetron will over heat without fan.
Apr 26, 2017 | Whirlpool Microwave Ovens
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Diswaher will not dry heating does not work
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 05, 2010 | Microwave Ovens
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Doesn't heat. Power works - evertyhing else
there is a fuse inside the microwave...power, clock will work but it will not heat when it blows
Nov 03, 2009 | Sharp R-510HW Microwave Oven
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
