Question about Samsung HT-Z320T Theater System
Back ground sound is so high you can't hear the dialog ,meaning having \r\nto turning ssound up way too high
  • 635 Answers
This can mean only one thing. Your center channel is not working. Either you have a damaged center speaker of you have a damaged center amplifier. You can confirm by first turning down the volume to normal levels and disconnect any one of the speakers and connect it to the center channel output. If you can hear the dialog the center speaker is defective.
Another way to hear the dialog is to change the surround setting to PL II music or just disable surround and chose Stereo mode.
Posted on Mar 28, 2011
Aurora 4.0 im stumped checked starer relay and car still wont start clicking ssound comin from backseat jumped it whats wrong
What year vehicle ? The clicking sound you hear from bake seat is probably a relay ! There is a fuse / relay box under the back seat ! How did you check the starter relay ? Just pull it out an look at it ? Was it #36 START 1 Relay
-- Starter Solenoid and PCM in the under hood fuse / relay Box ?
This relay is computer energized - PCM supply's a ground to circuit 447 which energizes the relay sending voltage to the starter S terminal engaging the starter . Do you have a test light or a volt ohm meter ? If you pull out the starter relay an look on the bottom you will see some numbers , 85,86 an 30,87 . match them up to the holes they came out of . Check out this video on YouTube ,you can check for voltage an computer control . Is the SECRUITY light lit on the dash ?
This VEHICLE RELAYS Operation Diagnosis VEHICLE RELAYS Testing from the relay base
Aug 11, 2015 | Oldsmobile Aurora Cars & Trucks
When playing a blueray movie I can hear back ground music and noise but not the people talking
For this particular problem, you have a mismatch between your Blueray player and your home theater system. It sounds like your Blueray has the audio set to Dolby Digital which has most of the dialog correlated to the Center Channel Speaker and your home theater system set to stereo. Once you get the two talking the same language, so to speak, you will be able to hear the dialog.
If you have both Digital connections such as Digital Audio RCA or Digital Optical Toslink as well as Analog L/R audio connected to your HT system, you can remove on or the other and trouble shoot from there.
I hope this information is helpful for your system fix.
Feb 27, 2015 | Televison & Video
The phone rings, however I cannot hear the caller
A sound settings have been reduced on the phone or possibly disabled from producing any at all. The sound could be re-enabled by locating on the phone the settings icon and navigating with the arrow keys until the sould iocns could be re-adjsuted. Once at the ssound icon on the phone, useing the option buttons to select sound instead could be customised by increasing volume scroll bar up and down to until found suitable ring tone.
Dec 05, 2010 | LG Cell Phones
I have a panasonic TH-50P V600 TV, the sound in
by any chance do you have the set in suround sound if you do change it back to stereo.. and try that most of todays set have poor sound and tiny speakers. because so many people connect there set to a theater system
Dec 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Poor dialog sound of Yamaha RX-V363
I'm working on one right now. It seams that you are not selecting to correct program for the dialog. I would not use music enhancement on dialog content.
Jul 15, 2009 | Yamaha RX-V363 Receiver
You turn on the tv then it turns off right away with no picture displayed could probably used new screen too
The repair of this unit will be determined by the status of the high voltage on initial power up. You need to do a few tests in order to narrow down what the high voltage is doing. You will need someone to assist you.
Unplug the AC cord. Remove the rear lower cover from the tv. Make sure the room is quiet. Put your ear inside the tv being careful not to touch anything metal, although most metal objects are ground. Next, have someone insert the cord into the AC outlet while listening very carefully. What you are supposed to hear is a click which is a relay and high voltage snap up. If you do not hear a swishing sound, which is the sound of high voltage have someone press the power button on the front while you are still listening. If you hear the swishing high voltage sound come on, it will come on and stay on, or collapse. Repeat the test, unplug the cord and plug in the cord to confirm the high voltage is coming on and staying on or coming on and going into collapse.
If the high voltage does not come up at all it means that there is a basic high voltage power supply problem and an experienced technician needs to guide you through a high level repair which is above the scope of this discussion. You may want to contact a skilled technician.
If the high voltage comes up and collapses right away, which is the most common fault, it means that the unit is entering the protection mode. The protection mode is most commonly caused by convergence or vertical sweep system on that model and big screens in general. These repairs can possibly be done by consumers with basic electronics knowledge. If you want to repond with test results we can supply more information on repairing the convergence or the vertical sweep system.
If the high voltage stays up then the likely fault is a power supply problem is muting both the video and the audio causing the unit to go into protect. Consult a service manual, track power flow though out the unit to determine which circuit is impaired.
Apr 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
No dialog sound when watching DVD's
The problem is that your center channel is not functioning correctly.  Dialogue is typically routed to the center channel only in 5.1, so if you don't have a working center channel all you will get is sound FX and background sound.
Go through all your settings, verify that they are correct.  Verify that your center channel is working properly, and wired to the correct output.
Test the center channel speaker and I feel confident you will find something amiss.
Dec 09, 2007 | Koss KS2503 System
Sound not good
could have blown the speakers or if there sub woofers ran off an amp that might be your problem as far as the cause it could be something as simple as a loose ground or some wire that is getting power grounding out on a piece of metal somewhere i would double check all of your connections
Oct 04, 2007 | JVC KD-G200 CD Player
Off and On at mid and high volumes
sounds like you have a problem with your grounding on you amplifier. check for shorts on your amplifier and the place where you have it grounded. (or check the power wire also.)
Nov 01, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Samsung HT-Z320T Theater System Logo
182 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
