SOFTNER STILL IN THE DRAW WHEN WASH HAS FINISHED
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Posted on Mar 28, 2011
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Washing Machines
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Fabric Softner section won't fully drain....
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
My machaine no longer takes the softner when on rinse .
open the soap drawer when softener should be taken and see if there is a jet of water into the conditioner box. if not, a common cause is the jets in the roof of the box blocked. poke a hairpin in the holes in the roof of the box and see if this cures the problem. if the rinse water does come in, this means that the actual water valve is ok
May 18, 2007 | Hotpoint WF645 Front Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
