Today I cleaned my keyboard using a foam, after then it is not working any more.
    Brigadier General:
  • 8,909 Answers
I would take a look on ebay for a replacement keyboard. They are fairly easy to replace. If you decide to replace it yourself get back to Fixya for instruction when you have the replacement, otherwise a trip to the repair shop is required.
Hope that helps.
Posted on Mar 28, 2011
I have recently cleaned my laptop keyboard with computer cleaning foam. Since I used it my keyboard has stopped working. I have left it over night in a warm place but still no joy. Any suggestions? Thanks
Did you remove the keyboard PRIOR to cleaning?
Would suggest you use an external keyboard, plug into your USB port and type away.
This would help identify if its just the keyboard.
Apr 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
Tip
How to Clean the Laptop Keyboard
The following will completely solve keyboard problems and return the keyboard to perfect operation.
This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive.
  • This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE:IMPORTANT: Make a keyboard map so you know where each key goes.Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.CLEAN KEYBOARD ( do this well...... you will be wonderfully rewarded ) Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves. Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol. Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SPACE BAR.
CLEAN KEYS:Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease. Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS:Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS:Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD: Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry. All right, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE:Place all rubber components into the keyboard. Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place. Install the rest of the keys by aligning and firmly pressing down.
on Jan 03, 2011 | Computers & Internet
Beer spilled on my keyboard so they feel really sticky. How can I clean it?
  • Cleaning materials:
  • Cotton swabs
  • Paper towels
  • Rubbing alcohol
  • Water
  • Scissors
  • Kitchen strainer
Proceed as follows: DISASSEMBLE
CLEAN KEYBOARD
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don?t lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS
LUBRICATE KEYBOARD
REASSEMBLE
Oct 30, 2010 | Dell Studio 17 Laptop
Hp Compaq 6735s I clean it with multi purposes foam cleanser & the key board stop working since yesterday & I tried cleaning lt with a spirit
use of spirits in a keyboard is not recommended, it will eatup and destroy the rubber compounds that make the keys work. It can also damage the electronics inside. Find some canned air, try to dry it out as best you can with the air between the keys. Then try not to use it until it comes back to life. Until then try a usb keyboard in its place. Worst case scenario you will need to replace the keypad of the notebook. Its pretty easy fix though. Best thing to clean keyboards is canned air and windex on a paper towel for the key surfaces only. hope that helps. cheers
Aug 30, 2010 | Compaq Computers & Internet
Have had this Asus 50IN for 2.5months. After 1 month some of the keys on the keyboard started to become intermittent. Comma "," and the Period "." especially. Now after 2.5 months, the "v" is not working...
Use a keyboard cleaning foam and spray to clean it. If this does not help maybe you need a new keyboard and since it has warranty then they should replace it for free.Hope that helped!!!
Mar 24, 2010 | ASUS K50IJ-C1 Notebook
I want clean the keypord of my laptop hp nx 6110?
Spray Lysol on a rag and wipe the keyboard or diluted bleach in water on a rag, rinse all the water out, and wipe keyboard. Let it sit and air dry for a couple of hours before powering on and using.
Feb 16, 2010 | HP Compaq nx6110 Notebook
Key button got pluged off
You probably broke a little tab that connects the letter to the actual button.
Just get some of that thick (foam) double sided tape. regular double sided tape wont work.
good luck
May 20, 2009 | Acer NSK8458AN Keyboard
Acer 240 laptop keyboard took sip of coke
Proper cleaning and lubrication as described here will restore your laptop keyboard to the snappy and smooth performance it had when new. This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Paper towels
  • Rubbing alcohol
  • Water
  • Scissors
  • Kitchen strainer
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive. This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE
CLEAN KEYBOARD
Do this well...... you will be wonderfully rewarded
CLEAN KEYS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely. LUBRICATE KEYS
LUBRICATE KEYBOARD
Alright, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
CONTRATULATIONS, you now have a squeeky clean keyboard!
Jan 12, 2009 | Acer TravelMate 240 Notebook
Sticky keys
You can try cleaning the keyboard. most keys can be removed easily by just pulling them out.
  • Cotton swabs
  • Paper towels
  • Rubbing alcohol
  • Water
  • Scissors
  • Kitchen strainer
CLEAN KEYS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don�t lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS
LUBRICATE KEYBOARD
REASSEMBLE
Nov 16, 2008 | Compaq Keyboard
Clean the keyboard
Use only a dry cloth. Do not spray any liquids or foam cleaners on the keyboard.
Sep 14, 2005 | NEC MobilePro 250e
Computers & Internet Logo
David Payne
David Payne
