Teka LSI3 1300 dryer Washer does not heat up during drying cycle
  • 1294 Answers
SOURCE: hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 26, 2008
  • 1003 Answers
SOURCE: washer dryer - dryer does not heat up
REPLACE HEAT ELEMENT TO SOLVE DRYER PROBLEM
Posted on Feb 02, 2008
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 25 Answers
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
Posted on Jun 03, 2009
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Posted on Dec 02, 2009
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Feb 04, 2017 | LG WM3987HW Front Load Washer / Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
I need a manual for a teka washer/dryer A ls13
We have a Teka washer/dryer A-L512 1200 and all the clothers are comming out with fluff on and the dryer takes too long to dry. We can't find the filters, where are they?
Jul 15, 2009 | Washing Machines
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
