Question about Refrigerators
After i clean it up it doesnt produce coolness
  • Babu Raj
    Babu Raj Mar 28, 2011
    1) Inside fan working?
    2) Compressor (back bottom side ) working vibration feeling?
    3) Knob too low number.?
    4) Light on?
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 28, 2011
What year was Amanda air command high efficiency 80 gas furnace produced. Have problems with dust. Notice furniture gets dusty when furnace on.
The year it was produced has no relevancy on tyhe dust in your home. You may want to consider having your ducts cleaned and possibly a pull and clean on your blower wheel. Also a good cleaning on the evaporator with routine filter changes will help with dust as well. Best Wishes.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 21, 2017 | Heating & Cooling
How to check problem with john deere 200d lc cooling motor stoped moving
if i understand you right your saying the cooling fan doesnt work at all , yes it's run by a electric motor , it's triggered by the ECM via a control relay /fuse that gets a cool /notcool signal from engine coolant sensor any of these not working correct will produce the effect u see, normaly this will make the fan ,Modulate (off/on) for diff enviroments like mine doesnt even run when plowing snow but runs all the time plowing a field , due to diff time of year
Dec 15, 2014 | John Deere Garden
Admiral side by side fridge is not staying cool
Hi, fridge produced today's time do not possess the condenser on the back of the fridge but underneath. Most people handled exclusively fridge and uses. The problem begins when after some time of use
accumulates a large dirt suspension that starts to block the airflow that cools the gas flows and who to be with cool before it flows to the evaporator to colder gas produced in the evaporator temperature minuses. If the gas is hot at the entrance of the evaporator does not produce a very low temperature as well as produces more ice who eventually begins to block the flow of cool air inside the refrigerator. It should also check de defrost circuit who also may be damaged. What should be tilted for cleaning your refrigerator and use the vacuum cleaner from time to time.
Jun 17, 2014 | Admiral 26 cu. ft. Side-By-Side...
Heat doesnt work in my jeep cherokee when driving but when sitting heat works
Put a piece of cardboard in front of the radiator. Only if it's cold out though, Usually in really cold weather, the cooling affect of the cold air circulating around the radiator keeps the fluid from getting hot enough to produce heat unless your running in park.
Dec 17, 2013 | 1998 Jeep Grand Cherokee
We have a delonghi pinguino pac-t105 which just doesnt get very cold.
Instructions Things You'll Need:
  • Clean cloth(s)
  • Garden hose (if necessary)
  1. Verify that the air conditioner is connected to a power supply if the unit is not operating. Reset the circuit breaker or fuse if necessary and ensure that the electrical cord is plugged firmly into the unit.
  2. Clean the condenser coil with water from a garden hose and wipe down the fan motor blades with a clean cloth if the air conditioner is flashing a yellow alert light or is not operating or cooling as expected. Remember to turn off and unplug the air conditioner prior to maintenance.
  3. Adjust the thermostat to a warmer setting if the air conditioner is producing air that is too cold. Adjust the thermostat to a colder setting if the air conditioner is not producing enough cold air. Allow a few hours for the colder or warmer setting to take effect.
  4. Clean away leaves, dirt, branches or other debris away from the main unit if the air conditioner is not functioning well or the motor is running excessively. Clean the grilles and vents to allow for proper air flow.
  5. Contact an authorized service professional if the above steps do not resolve the issue
Jan 17, 2011 | DeLonghi Heating & Cooling
LG Air Conditioner leaks water
A/c units produce water, unit must be tilted outside so water doesnt come into house.
Aug 21, 2009 | LG Heat cool Window Air Conditioner
No hot air is being produced from my Zanussi TC 180 condenser dry
what make is it?is it a top lint screen or inside?
Mar 31, 2009 | Dryers
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Is this referigerator works on vapor absorption cycle?
wow you must have some knowledge about refrigeration systems.
as with all freon based systems, they do work on temp absorption. you must also know that a so called "cooling" device doesnt actually cool, but it takes away heat.
this is how they produce a cooling effect and remove heat from the items we want cooled.
like a refrigerator or an air conditioner.
they all use compressors and freon to absorb the heat from the place we dont want it.
if you need more info just reply here.
thanks tzweeb
Feb 03, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
