Question about Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
I have IR compressor type 30 model 231. i have dipped compressor in water tank with new pipelines and vessel for acetylene gas filling. But Current of motor is fluctuating between 1.6 ampere to 2.8 ampere.WHY ?
  • 22 Answers
SOURCE: Where can I find the owner's manual for an IR Type 30 model 25T
IR has not made their owner's manuals available online. You have to contact your nearest dealer in order to get one. If you do get one, could you please consider uploading the manual to fixya.com to help other people who a looking for the same thing.
Posted on May 13, 2009
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
  • 17 Answers
SOURCE: need compressor parts for type 30 Ingersoll-Rand Compressor
contact ingersoll rand they are helpful http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
mrhappyface
  • 205 Answers
SOURCE: Hi, I have an old IR Type 30, two-stage
no you need to use a compressor duty motor same rpm using a higher rpm motor will shorten the life of the motor if you have 3 phase power even better single phase motors aren't as efficient and run much hotter and dont last very long on air compressors
Posted on Aug 23, 2010
Testimonial: "Thank you for your reply. It reaffirmed what I already thought, but I needed to be certain."
puertobori
  • 7733 Answers
SOURCE: I have just fited an IR type 30 compressor to my
Trt this link IngSoll.
Posted on Oct 13, 2010
I have an old type 30 model ingersoll rand air compressor. It has not run for years, we just wired it up and ran it for about 5 minutes. After that, I thought I better check the oil level... There does...
Alot of the older units did not have a sight glass. They had a dip stick on the fill plug. Over the years they broke off or the oil fill plug was replaced with a newer type that does not have the dip stick. To answer your question dip stick or not I always fill with oil to the bottom of the threads on the fill plug. You should remove the plug and check the oil level before each use on and older unit like this until you have a good handle on how much oil it uses. you may also be able to remove a plug usually on the front of the case lower left side and install a sight glass or low oil level switch. Have a good day!!
Nov 12, 2011 | Ingersoll Rand - Rand Type - 30...
What weight of lubrication do i use for this compressor...Ingersoll Rand TS4N5? And do I need to bleed the tank off before adding oil?
Yes it is always a good practice to bleed the tank down. there is a check valve in the top of the receiver tank that keeps air from blowing back Thur the system. However if it's leaking you will have pressure on the oil sump. As for type of oil use a 30 weight non detergent oil. Recommend using ir's t30 all season or another type made for air compressor's.
May 23, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Hard starting does this model have an unloader
There are two types of unloaders used on IR compressors. One is oil pressure controlled, and second is manually activated for starting. According to the photo and model number provided, yours is manually operated. Follow air line from compressor to tank. The pilot valve (brass valve) between airline and tank is a multi-function component. There is a flip leaver or pull ring w/ hold that unloads the compressor by venting air thru small muffler. The valve also contains the check-valve holding pressure in the tank, a means of adjusting pressure and controlls throttle for engine. For easy start, flip leaver upright and start; to run, flip leaver to right angle of stem.
Nov 19, 2010 | Ingersoll Rand 2475F13GH Ir Stationary...
My compressor 2475 ir (5hp) has no dip stick or oil level glass;only oil cap.how much oil is needed for proper level?
In the owners information your compressor takes the 1 bottle of IR oil that comes with it. If you have a local tractor supply company or another company who carries IR you might check with them, it is the only oil i would recommend for your unit.
Jul 19, 2010 | Ingersoll Rand - Rand Type - 30...
Motor takes high current and trips on over load
Maybe your are in low voltage thats why amphere is high.
May 11, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
I want to change the outlet from it's current 1/2'' to a 3/4'' outlet. I have an IR model SS5N5 air compressor.
To change it like that, you will have to remove the 1/2" outlet, bore it to size and weld in the 3/4" outlet. Don't try it if you're not a pressure vessel certified weldor. If the weld isn't 100% good, you could either have a bad leak (not problem) or it sould shoot the new fitting out like a bullet.
Making a change like this really won't accomplish anything other than empty the tank 50% faster.
Jan 09, 2010 | Ingersoll Rand Compressors 5-HP,...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Ingersoll Rand  Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage  Logo
57 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
