Question about Vizio 42 in. LCD TV
The tv come on then goes back off want to know if worth getting fixed
  • 734 Answers
When TV goes off by itself, its because of possible overheating. Sometimes you are lucky, and it is only moisture on the electronic circuit. Dry weather may heal it. People usually kee TV in standby to keep moisture out. It could be ccfl bulbs aging, and inverter may need fixing together. You need service, because 42" TV has many many bulbs. You could try using a fan to dry out the TV circuits for a few days and see if you really need service?
Posted on Mar 28, 2011
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
Tv screen goes black.
t-con board board failing or the cable needs reseating, meaning unplugging and putting back on a gain. t-con board is the one screwed to the back of the screen with a metal shield covering it.
Feb 01, 2018 | Televison & Video
I have a CSC35313 tv. When you first turn it on, the picture is great. After a while, it starts getting a grayish haze over it until you can barely see the picture. Then every once in a while, the haze...
Yes,This problems is easy to fix.U know how to solders?Take the tv aparts.Resolders the video board holes socket that connect the video board to crt tube.
Feb 25, 2010 | Televison & Video
Sound but no picture
Start by eliminating the variables. Connect a source that you know is working (e.g. a VCR or DVR that is working on another TV) to your TV. If you get the same result, connect it to a different input and, if possible, different input type. If you still get the same result, your TV is bad. Most standard TVs are not worth fixing since it costs almost as much to fix them as to purchase a new one.
If changing the input fixes the problem, the TV has a bad input and you can just switch to a new input.
If changing the source fixes the problem, your source is bad and needs to be repaired or replaced.
Be sure to use cables that you know to be good by testing them on another source/TV system.
If changing the cables fixes the problem, then replace the cables.
Dec 05, 2009 | Cell Phones
Screen goes black
not worth fixing,techs charge at least 65.00 $ an hour not including trip charge.no easy fix. you can get new lcd flat panels for under 500$ now. especially at best buy,ther giving them away
May 19, 2009 | Sony KV-32XBR450 32" TV
Screen goes blank.
PETTY SOON YOU WILL NEED A NEW MONITOR, IT PROBLY IS NOT WORTH FIXING,
TAKE IT TO A TV SHOP AND LET THEM LOOK AT IT, THEY CAN TELL YOU IF IT IS WORTH FIXING
CANDYMANGANDY
Jan 29, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
