Question about Hasselblad 503CXI Medium Format Camera
Hi, I have detached the magazine on my Hasselblad and now I cannot put it back on. The pin on the lower right will not connect to the body, as the receiving part is somehow locked. I used to be able to gently rest the magazine on the hinges and then gently get the magazine into position and connect the two parts. Do you know what I could do to fix it? Regards, Johan
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Posted on Aug 19, 2009
SOURCE: Underwater housing parts
Hi this is an old housing you have to make the parts yourself, film advance adapter, it is dificult to make one. But toothed diaphram and focusing ring is easy
Posted on Sep 29, 2010
Hi I have a Hasselblad H1 the highlights are suddenly "crazed" any idea what could be causing this?
I'm not used to Hasselblad. (Out of reach) I wonder if the thing you call crazed is blinking of the highlights, indicating you over blown that part of the picture. It is your decision, if you leave the overblown parts as they are, or retake the picture one or a few stops lower.
Jun 12, 2014 | Hasselblad Photography
Put thule hinge back on
Hi Jonathan, based on the date of your Q, you may have already moved on. For what it's worth... I have the Atlantis 1600, structure is identical, cubic feet size is different. When you state "put Thule hinge back on" I am presuming you're referring to the entire upper segment of the carrier as the hinges are only pins riveted to the upper carcass. These pins seat in the lower carcass latches (also riveted) when the lid is closed. If the lower latches are obstructing the pins from seating, it means the latches are locked -- simply insert your key and unlock them. The pins (hinges) will function normally again.
If you're referring to actually attaching the pins to the upper carcass, then I would use a 3/16" medium length rivet ensuring that you use a washer on the inside (where the rivet expands) to add the binding power that the carcass body will not.
Aug 03, 2012 | Thule Atlantis 1200
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
Do I have to take the top in take manafold off to tighten the lower intake manafold on a 1993 buick regal 3.8 L engine?
Yes you do, the following info explains the necessary procedure.
Click here to enlarge image.
  1. Properly relieve the fuel system pressure.
  2. Disconnect the negative battery cable. Place a clean drain pan under the radiator, open the drain **** and drain the cooling system.
  3. Remove the air cleaner assembly and the fuel injector sight shield.
  4. Disconnect the cables from the throttle body and mount bracket.
  5. Remove the coolant recovery reservoir.
  6. Remove the inner fender electrical cover on the right side.
  7. Remove the right rear crossover pipe heat shield.
  8. Disconnect the fuel lines from the fuel rail and from the cable bracket.
  9. Remove the alternator and brace.
  10. Remove the throttle body cable mounting bracket with the vacuum lines and disconnect the vacuum lines.
  11. Tag and detach the electrical connections at the throttle body and both banks of fuel injectors.
  12. Disconnect the vacuum hoses from the canister purge solenoid valve and transaxle module and intake connection.
  13. Unbolt the power steering pump and move forward. DO NOT disconnect the fluid lines.
  14. Tag and disconnect the spark plug wires position lay aside.
  15. Disconnect the coolant bypass hose from the intake manifold.
  16. Remove the solenoid valve mounting bracket and power steering support brace from the intake manifold.
  17. Disconnect the heater pipes from the intake and front cover.
  18. Remove the alternator support brace from the intake.
  19. Disconnect the upper radiator hose from the housing.
  20. Remove the thermostat housing and thermostat from the intake.
  21. Detach the electrical connector from the temperature sensor and sensor switch.
  22. Unfasten the intake manifold bolts, then remove the manifold as an assembly. Remove and discard the gaskets.
  23. If separating the upper manifold from the lower, proceed as follows:
  24. Remove the fuel rail and fuel injectors.
  25. Detach the coolant sensor switch.
  26. Remove the manifold end cap cover.
  27. Remove the upper intake manifold and throttle body assembly from the lower manifold. Remove and discard the gaskets. To install:
  28. Thoroughly clean all gasket mating surfaces.
  29. If replacing the upper manifold, proceed as follows:
  30. Apply a 1⁄16 in. bead of Loctite® Instant Gasket Eliminator 51845 or equivalent to the lower manifold mating surface. Make sure to circle all bolt holes.
  31. Carefully lower the upper manifold and throttle body assembly onto the lower manifold.
  32. Tighten the upper manifold retaining bolts to 19 ft. lbs. (26 Nm).
  33. Install the manifold end cap cover and the coolant sensor switch.
  34. Install the fuel injectors and rail to the manifold assembly.
  35. Clean the mating surfaces and install the intake manifold gaskets and seals. Apply sealer to the ends of the of the intake manifold seals.
  36. Position the intake manifold and apply a suitable thread lock compound to the bolt threads. Tighten the retaining bolts to 88 inch lbs. (10 Nm), twice, in the sequence shown in the accompanying figure.
  37. Attach the electrical connector to the temperature sensor and sensor switch.
  38. Install the thermostat housing and thermostat with a new gasket.
  39. Connect the alternator support brace to the intake.
  40. Install the solenoid valve mounting bracket and power steering support brace to the intake manifold.
  41. Connect the heater pipes to the intake and front cover.
  42. Attach the coolant bypass hose to the intake manifold.
  43. Install the power steering pump support bracket and tighten to 37 ft. lbs. (50 Nm).
  44. Install the spark plug wires on both sides.
  45. Install the belt tensioner pulley and tighten to 33 ft. lbs. (45 Nm).
  46. Install the power steering pump.
  47. Connect the vacuum hoses to the canister purge solenoid valve and transaxle module and intake connection.
  48. Attach the electrical connections at the throttle body and both banks of fuel injectors.
  49. Install the alternator and brace.
  50. Connect the throttle body cable mounting bracket with the vacuum lines.
  51. Install the right rear crossover pipe heat shield.
  52. Install the cables to the throttle body.
  53. Connect the fuel lines to the fuel rail and mount bracket.
  54. Install the inner fender electrical cover on the right side.
  55. Install the coolant recovery reservoir and upper radiator hose. Fill the cooling system.
  56. Install the air cleaner assembly and the fuel injector sight shield.
  57. Connect the negative battery cable.
Jan 31, 2011 | 1993 Buick Regal
I have a Hasselblad 500c/m with the lens stuck on the body and I not turn the shutter knob. Help!
Get the back off the camera, make sure you can see inside the camera and locate a chrome screw in the middle below the lens.
Turn it right to align the locater slot of lens and body. Be very careful and do not use to much force. If you turn it enougn you can use the release button an unscrew the lens by turning it anti-clockwise.
Sep 19, 2009 | Photography
I can not get the Magazine to release. I see where it say's Manual Magazine realease, but can't tell what to do. Please help Darrell Mack
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Reduce the output level from any external components connected to the music center. Make sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1 jack and the multi-pin connector on the other end is firmly seated in the Accustoms module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers to the Accustoms module. To restore communication between the music center and the speakers turn the music center off for ten seconds, then on again. Check the connections for any external components. Make sure to select the correct source for the desired input. Be sure the CD is placed correctly, label-side up, in the magazine, and the magazine is inserted properly in the music center. Increase the volume. Check to see if MUTE is lit on the display. If it is, press the MUTE button on the remote control to un-mute the sound. Disconnect any headphones. Connect the FM and AM antennae. Check to see if the play symbol in the display is lit. After pressing the CD key, wait a few seconds before pressing PLAY. Make sure the magazine is properly inserted. Check to see if there is a disc in the magazine, label-side up. Display shows a flashing box for a disc that is label-side down or cannot be read. There may be dirt or dust on the CD. If so, clean the CD. Eject the magazine and try loading the CD again. A display message “E01” indicates a mechanical error. Unplug the music center. Reconnect power and try again. If “E01” reappears, call customer service.
If the CD stuck again as you stated in your earlier comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside down so that the "Manual Magazine Release" is in your upper right hand. Locate the two small rectangular "Open Slots" on the side. You need to use the top slot. Use the screwdriver and push the little "U" or "Y" Shaped metal upward which is just below the manual release. The magazine will come out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Bose Lifestyle 20 System
Aug 17, 2009 | Hasselblad 503CX Medium Format Camera
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
Hasselblad 555ELD
I would check the top latch plate first. They do have a tendency to become loose. The latch points at the base could be slightly bent too.
Jul 24, 2008 | Hasselblad 555ELD Medium Format Camera
Which Hasselblad?
There were several versions of the 500C/M as production was over many years. The 501C had all the latest revisions of the 500 C/M series to make it the better choice. You'll get more $ for the 501 for this reason. Later versions of the 500C/M had a much better coil spring to control the mirror for starters. Unless you are going to use this camera for daily professional use, either would be a reliable camera. A good way to check the amount of use on any Hasselblad is to look at the back of the camera where the film magazine mounts. A good solid black with no shiny spots on the plate would indicate little use. There are raised lines around the aux. shutter opening that will wear as film back are removed and replaced.
Nov 12, 2007 | Hasselblad 203FE Medium Format Camera
Hasselblad 503CXI Medium Format Camera Logo
264 people viewed this question
Top Hasselblad Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
