Question about Canon iR 2016i Black and White Copier
Want to know where to buy replacement parts; fuser and fuser film and pickup rollers
  • 1,219 Answers
try on www.katun.com for OEM parts or on nearest canon service shop!
Posted on Apr 12, 2011
How do I replace Fuser Part RM10865000CN.It is a Roller with some kind of plastic film on it.Not sure how to remove old part.
The fuser part is a fuser assembly. I think you can remove the assembly which is not much difficult. Remove the screws, connectors. You have to remove the tight springsor any other screws holding the metal L plate,. Remove the roller then the fuser. Remove the lockable end cap of the fuser at the other end where there are no heater wires. Remove the fuser film (which you called plastic film). Replace it with new one. Normally it is required to be replaced if it is torn or have holes caused by foreign materials or the life is over. If you are still unable to do it, write me back.
-sonsunny
Jul 18, 2011 | HP LaserJet 3030 All-In-One Printer
In our printer it seems the teflon roller is found defectgive and in all the print one side is smudgin.
This is a very common problem as the fixing film shreds its end and continues to move along the roller until half of it has left the machine. You can buy the film on its own but it better to replace fuser as an assy.
for the 120v fuser the part number is RM1-2086-000CN
and for the 240v the part number is RM1-2096-000CN
Hope that helps.
Jun 25, 2011 | HP LaserJet 1020 Printer
Our epson aculaser c4000 makes a loud whistling sound and the paper jams, it jams in the fuser unit.
Basically there is a grease on the inside of the film on the fuser, the film is a grey colour the orange roller is what is called the pressure roller. what has happened the grease has worn out. you can get buy one from this site which i have used many times
http://www.getprice.com.au/Epson-S053018-Fuser-Unit-220V-Compatible-with-AL-C2600N-2600N-80000pg-S053018-Gpnc_217--35190949.htm
Also if not you could try and re-grease the fuser film yourself for free
http://www.copierscopiers.com/store/Canon-Fuser-Film-FUSER-FILM-WITH-GREASE_p_64-469.html
this is the grease you will need but i couldnt find a site that sold the grease on its own.
i hope this helps
Mar 08, 2011 | Epson AcuLaser C4000 Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
I have dark lines all the way down on the left side of paper. I replaced the toner cartridge, and still having the problem.
It seems that the fuser film roller is damage and need to be replace. Only tecnichian can fix the problem because they will open the whole printer.Fuser film roller is color orange that u can see through. It is quite damage due to high volume of printing and this fuser film roller start to tear up from sideways. Or the black fuser roller is damage. Just try to clean this with alcohol and see if it works.
Dec 29, 2010 | HP LaserJet 2420 Printer
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
I have a problem with the roller just before the paper is printed out. Sometimes flakey pieces of the roller are chipped off and sent out along with the paper. Do you know how to fix this or where to...
doesn't sound like a roller ... it's probably the fuser film sleeve. google for a sleeve .... or a (refurbished) fuser unit. if you've never replaced a film, that is the better choice.
Sep 24, 2009 | HP LaserJet 1012 Printer
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Canon iR 2016i Black and White Copier Logo
old marine
old marine
