Question about Vacuums
Russell Hobbs RHI 405 iron - Iron switches on but does not heat up
  • 17,130 Answers
Please check the mains cord and see if there is continuity of the main wire, from the plug to the iron. Now check the continuity of the heating element and also the functioning of the thermostat.
These test must show a continuity or the main-heating element is open.
Posted on Mar 28, 2011
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
Russell hobbs vacuum model no 18213 can't get bags?
You can get Menalux 1900 for Russell hobbs vacuum model no 18213 which fit perfectly. Also you ca buy SENCOR SVC 900 bags which fit perfectly and you get 5bags in one package + filter for very good price.
Also there are moe bags that fit to this vacumm model.
Jan 22, 2012 | Vacuums
My steam glide russell hobs iron pours out water when used I have burnt my self a few time. It also leave the garment very wet.
Many persons put too much water in a steam iron.
Make sure that you do not fill it all the way to the brim.
Try using less water in the tank.
This may also solve your wetness problem.
Aug 29, 2011 | Vacuums
I am looking for russell hobbs hepa cyclonic 1800 (14043) parts and not having much success could you point me in the right direction please?
Wow, doesnt seem like its gonna be easy but here is a contact site you can try
http://www.russell-hobbs.com/parts.shtml
I hope they can help you out.
Good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Power switch on iron heats up but no steam generation
The holes on the bottom of the iron are probably clogged up. Use a straight pin to clear the holes.
Mar 15, 2011 | Vacuums
I need a manual for russell hobbs 10661 as been given one without instructions....
A Russell Hobbs 10661 is an espresso maker - not aware of a Vacuum cleaner with that model number . Are you SURE you have the model number correct?
Jan 31, 2011 | Vacuums
Euro-pro iron. red light on. green light blinks on but iron will not heat up. lights do not progress through yellow (does not go past green) purchased from walmart with warranty extention on 12/08. ...
When the green light stops blinking and is solid, the iron is ready for use. Touch the handle and begin using. but as you mentioned that green light is blinking and the iron is not heating then there is definitely a short in wire some where it has to be checked.most probably its the short in the heating coil wire.but if the heating coil wire is proper and not short then your irons heating coil probally went bad its alot cheaper to just buy a new iron .because heating coil costs near to new iron.but still get confirm if its short in wire. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 18, 2010 | Vacuums
Vacuums Logo
123 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
