Question about Dishwashers
My Inglis dishwasher (E71195), 13 years old, doesn't clean properly. There is a film on everything that is especially noticable on glassware. I have cleaned every filter and unclogged everything that I could think of. I tried different detergents; right now I am using the same stuff in the dishwasher as we use to clean the milking equipment in our dairybarn because it gives the best result. It still is not as it should be however, there is still something left on the bottom of the glasses. It is easily cleaned off with a sponge and soap but that is not the point of having an automatic dishwasher. What else can I do?
    Top Expert:
  • Dishwashers Master
  • 52,082 Answers
Check the water temp as the heating element may not be working and getting the water hot enough
Posted on Apr 12, 2017
catriver
  • 878 Answers
SOURCE: Kenmore dishwasher 15899100
Dennis, Im assuming your model number starts with 665. This model had a service flash on it regarding the upper spray arm. The upper spray arm has been redesigned for better performance. Part number 8269022. This could be covered by Sears if you mention the service flash, 22-714. Other issues that can lead to this problem are; water hardness, if your water is over 7 grains of hardness, this could to this film on the glasses. Try pouring 1/4 cup of Glass Majic into the bottom of the dishwasher. Also run one cup of white vinegar to clean the dishwasher. Make sure the water temp. entering the dishwasher is 120 min. to 150 degrees. Catriver..post back.
Posted on Oct 30, 2006
SOURCE: Dishwasher not cleaning glassware
Sounds like no rinse-aid.
Posted on Apr 15, 2008
VOTIT
  • 2071 Answers
SOURCE: Subject is Bosch dishwasher SHU6800.
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Posted on Aug 17, 2008
  • 403 Answers
SOURCE: My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Posted on Sep 30, 2009
  • 901 Answers
SOURCE: Glassware keeps coming out cloudy and spotty. Have
Use the detergent meant for dish washers. Fill the rinse aid dispenser as per the user guide.If the water quality is hard. Use softeners. If dish washer salt adding provision is provide fill the dispenser.
Posted on May 20, 2010
How do you eliminate the film on glassware after washed in dishwasher ?
Your heater may not be working properly. It is used to heat the water during the main wash as well as dry the dishes at the end. But don't under-estimate the importance of using the right detergent. Some discount detergents (especially liguids or gels) don't work very good. Stick with Cascade or Finish powders or those All-In-One tablets by Finish corporation (the ones with the little red "power ball"), or the new tablets put out by Cascade called "Platinum". In our repair business and experience, we find those work best.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 30, 2014 | Kenmore Dishwashers
GE Profile dishwasher doesn't clean!
If you have "powdery film" it sounds like hard water deposits to me. Many states have outlawed phosphate as an ingredient in dishwasher detergents, so the detergents don't work as well anymore if you live in a region with hard water. New product designed for this very problem. "Greenest" product ever...it's all-natural and comes shipped to you in a re-claimed water bottle!
www.CloudyDishes.com
CitriClean of Florida CitriClean of Florida
Jul 21, 2012 | Dishwashers
Our Maytag MDB9100AWB is 5 years old. Have had repairman out several times. Problem is a light cloudy scum on everything. He has replaced several items, has had us clean parts and fixtures, etc and even...
There are three typical causes of chronic cloudiness on glassware/dishes.
  1. The incoming water may be too hot. Make sure the water is at or below 140 degrees F.
  2. Test to see if cloudiness is removable by hand cleaning or soaking for 5 minutes in white vinegar. If it is removable, it's due to hard water. Use a good quality detergent, and match the amount of detergent used to the water hardness and use a rinse aid. (Some low quality detergents clean poorly and leave a film.)
  3. Glassware may be etched, due to too much detergent, too high water temperature, or pre-washing. Etching is not reversible, so it's important to correct the problem promptly.
Hopefully these hints will help you to home in on the problem.
Dec 27, 2010 | Maytag MDB9100A Dishwasher
Soap (?) residue on dishes; also not getting them clean--food on
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
From Whirlpool:
+Heat of drying.
+Long/hot cycles.
Do the following:
Source(s):
JimmyC
Sep 30, 2009 | Bosch Dishwashers
White film/residue left on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. Dishwasher Magic is a good choice. works great.
Jun 18, 2009 | Kenmore Dishwashers
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
