Question about Packard Bell Easy One Silver 2120 Notebook
The formatting cannot continue... - Packard Bell Easy One Silver 2120 Notebook
    Brigadier General:
  • 8,909 Answers
This could be caused by hard drive physical errors. Try running CHKDSK/F to clear any logical errors and then try again.
Posted on Mar 28, 2011
8GB SD card says: MEMORY CARD REQUIRES FORMATTING After selecting continue SD card says: FORMATTING WILL DELETE EVERYTHING ON MEMORY CARD after selecting continue it says: FORMATTING... but then returns...
i guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
or
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Jan 06, 2011 | PNY 2GB microSD Memory Card
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
Will not format Memory Card for Use.
Hello my friend.
Try this tool which you can download clicking here.
It can solve your formatting problem.
- Download the file.
- Plug your memory card into your PC.
- Run the "exe" file that you downloaded.
- On the program menu select your device (memory card).
- Select FAT32 as file system.
- You may give a valid volume label.
- Uncheck the "Quick Format" option.
- Then start formatting your memory card clicking the start button.
This formatting will delete all the files in your memory card.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 28, 2010 | Kodak EasyShare Z740 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
Memory card requires formatting- I select continue then it says "formatting will delete everything on memory card-I select "continue" then it reads "formatting" and repeates itself
1. Make sure your SD card is not locked so the camera can format the card. If the camera still cannot format the card, try to format the card with a computer. If this doesn' t work, the card may be defective.
If the computer can format the card, the put the card back in the camera and then the camera should be able to format the card. The camera MUST format the card before the camera can save to the card.
Jun 11, 2009 | Kodak EasyShare V550 Digital Camera
Camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Jun 04, 2009 | Kodak EasyShare Z7590 Digital Camera
New memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
Memory card
this cam will work up to 2gb sd/mmc
what's the capacity of your card? if it's above that, it's really not gonna work with this cam
if your card is 2gb or lower
2 possibilities:
defective card - please try another card
camera memory reading problem - arrange repairs with kodak
Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
Shooting Speed Dropped
You can perform a Low Level Format of a memory card with this camera. Select Low Level Format under the following circumstances: - The continuous shooting speed has dropped. - The read/write speed of a memory card has dropped. If you perform a Low Level Format, the read/write speed of the memory card may recover, or the continuous shooting speed may improve. A Low Level Format may require 2 to 3 minutes with some memory cards.
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Packard Bell Easy One Silver 2120 Notebook Logo
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
