Question about Singer 132QRFB Mechanical Sewing Machine
SINGER fUTURA ce-200
I PURSCHASED THIS MACHINE A FEW YEARS AGO AND HAVE PROBLAY SUED IT FOR MAYBE 20 HOURS IN TOTAL TIME.
wHEN EVER i TRY TO SEW IT WILL MAKE AS MANY AS 8 STITCHES THEN BEEP AND STOP THEN WILL LET YO START AGAIN AND MAKE A FEW STITCHES THE BEEP AND STOP . i HAVE CHANGED NEEDLES AND DONE EVERY THING THE BOOK SAYS TO TRY FOR TROUBLE SHOOTING. doES ANY ONE KNOW WHAT IS CAUSING THIS IT IS THREADED CORRECTLY . i HAVE CHECKED EVERYTHING THAT THE MANUAL SAYS TO TRY. I AM NOT CLOSE TO A REPAIR COMPANY HERE IN nc hELP PLEASE. tHANKS FOR ANY HELP IN ADVANCE kITTIE
Trying to use my futura ce-200. original software hangs on Win7 machine, updated software just says: entry point not found... the procedure entry point splash textcolor@@yaxk@z could not be located in
http://www.futura-support.com/products/ce-200/software
Make sure you downloaded the correct update. Reinstall the original software. Now right click on the program file (.exe) file in the software folder (prob on c:, folder called Futura **). Mine is different than yours...so end of file will be different, so I put ** instead). After you open the file folder...right click on the program file & choose properties; choose Compatibility; Check the run as box (mine is set to winXP 2); and check the run as administrator box.
Try opening the program...if it opens...you can then do the update install.
May 15, 2014 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200
since it is a embroidery machine I would suggest the technican
to be on the safe side
Jun 03, 2012 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Is the Singer CE-1oo Futura Windows Vista compatible? Also, can you put a #1 card in it to do the alphabet?
No it's not, All Singer futura users should be intitled to a 100% refund, or Singer should install new chips in the c-100's for former users. This is obsurb! you invest in the machine, and when the software upgrades itself, you are unable to use your machine. This is so awful
Nov 07, 2009 | Singer CE-100 Futura Computerized Sewing...
Flashing red light
Are you sure you have turned the foot button underneath the machine back to normal stiching and also then again for embroidary and have you placed the protective cover back for normal stiching once you removed the embroidary arm.
Mar 08, 2009 | Singer CE-200 Quantum Futura Computerized...
Button hole maker on Singer Quantum Futura CE-200
Try to adjust the stich width on the machine maybe it can help
Mar 07, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Unable to sew straight stictch with singer futura ce 100
When I had this experience I cleaned the thread path under the plastic cover. There was a piece of thread caught between the disks.
Aug 09, 2008 | Singer CE-200 Quantum Futura Computerized...
Embroidery centering
From my experience with this machine it is not a problem with the machine itself, but a software issue. Maybe your computer is not compatible. My first suggestion is to try to uninstall AND completely remove ALL programs related to Futura. Then restart your computer. Now re-install ONLY the main program. See if this works. Do not get frustrated, this machine usually takes awhile to figure out. Training is important for 100% success. Good luck!
Jan 17, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 132QRFB Mechanical Sewing Machine Logo
20 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
