Question about Brother Office Equipment & Supplies
My dcp6690cw printer won't align properly even though I have followed the instruction in the manual
  • sarah_pease Mar 30, 2011
    I've sorted it thanks (by ringing Brother) I needed to gently wipe the clear plastic thread inside, with a tissue.
5 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: cannot align ink cartridges in my cannon mp160 printer
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
djgillstudio
  • 107 Answers
SOURCE: installed new black ink cartridge in HP PSC 2110
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Posted on Oct 06, 2010
  • 1833 Answers
SOURCE: Why won't my printer heads
As you tried all possible solutions and the problem still exists. There are no new solutions on this issue.
To solve this problem you need to replace the print heads. You can contact Canon for the replacement parts.
Good Luck.
Posted on Aug 02, 2011
Why do my pictures have tiny black lines running vertically thru them when I print pictures?
Hi
If you have recently changed one or more of the cartridges you may need to align the print head, the following steps explain the process:
To align printer from the printer display
1. From the Home screen, touch the Settings icon, and then touch Tools.
2. On the Tools menu, touch the down arrow to scroll through the options, and then touch Align Printer.
3. Follow the instruction on the screen.
To align printer from the printer software
On Windows:
a. From the Start menu on your computer, click All Programs, click HP.
b. Click the HP Photosmart 5520 series folder, click HP Photosmart 5520 series.
c. Under Print, double-click Maintain Your Printer.
d. Under the Device Services tab, double-click Align Printheads.
These instructions were copied from the manual at the following link
http://h10032.www1.hp.com/ctg/Manual/c03353113
If this doesn't fix the problem, you may like to check the HP support page for the 5520 at the following link ---> support hp com
Trust this helps, best regards Alan
Feb 11, 2015 | HP Office Equipment & Supplies
How to ram clear
Does this happen when you are printing or scanning?
Try to power off, unplug printer and power back on.
See PDF fromBrother:
http://www.brother.ca/en/products/pdf/manuals/MFC440CN-UG.pdf Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Dec 26, 2013 | Brother Any 8 Inks Dcp-6690cw Dcp6690cw...
Printer will not print or copy even though head cleaning and alignment suggest it can print
Assuming that you have tried all the trubleshooting sugestions in the
book and on line..? try and contact you local Canon customer helpline
they usualy have an expert handy who can guide you through the
more difficult programes,it's worth a try and it's free...goodluck T.C.
Mar 31, 2013 | Canon Pixma MP990 InkJet Printer
How to reset counter in brother dcp6690cw
Sir/Madam
It's Very easy to reset counter in brother Printer,I suggest You watch YouTube video For Your Brother Printer Problem,I Hope You resolve and get all Brother Printer Help after watching this video URL Link below:
How to Reset Purge Counter on Brother DCP J315W Printer
Or
In case You still need Help I suggest You Follow Us On:
Nov 13, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
I keep getting the message Alignment Failed.
hello deer1626, if a printer gives you a message alignment failed that means your catridges are not properly installed try removing the catridges and fixing them back you will get a notification of aligning just follow the onscreen instructions and thats all
Jan 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP 5510: "Press OK to print Align Page" appears permanently, even after performing the alignment. Fixya advised removing power to reset the printer, but that doesn't help. I removed and reinserted ink...
To simply bypass alignment, do the following:
Press and hold the Setup button.
Press the Up Arrow button. The printer should be ready to print.
If print quality is unacceptable after bypassing alignment, troubleshoot the problem as follows:
Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. Click here to see how.
Remove and inspect the cartridges. Click here for instructions. If the cartridges are new, make sure the protective tape covering the nozzles has been removed.
Reinsert the cartridges into the printer. Press Enter to align the cartridges again if prompted.
If the problem continues, check the cartridge ink levels. Click here to see how. Both cartridges must have ink in them for successful alignment, so replace empty cartridges.
Watch the area inside the front of the printer as the alignment procedure runs. You should see a blue light below the cartridges as they move back and forth. If you do not see the blue light, click the link at the top of this page to contact HP. The printer needs to be serviced.
Compare the alignment page produced by the printer to the illustration below. If any of the colors are missing, run the Clean Print Cartridges utility. Click here for instructions.
Abbildung 1: Alignment page
If the problem continues, clean the contacts. Click here to see how.
If none of the steps above solve the problem, replace the cartridges or have the printer serviced. Click here to see how to decide whether to replace the cartridges or service the printer.
Let us know if that was helpful,
Thanks
Shiv.
Aug 23, 2009 | HP Officejet 5510 All-In-One Thermal...
Lexmark 2500 printer problems
its very possible the new cartridge is faulty. I would suggest getting another one. Some new cartridges are acutually refurbished and just refilled and sold. Eventually they stop working correctly.
Joe
May 26, 2009 | Office Equipment & Supplies
HP F380 Error message
your alignment is not detected properly
first check your print cartrages are ok or not if it is ok the align print cartage and put it in the scanner and once scan it
Jul 18, 2008 | HP DeskJet F380 All-In-One Printer
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
