Question about Whirlpool Washing Machines
I need to know if your Cabrio top loader will pump the water out to a pipe that is 90 inches above the floor
Had ld code in before it began to spin
Posted on Jan 17, 2009
  • 5,911 Answers
The drain line should be no more than 72 inches above the floor, or you will experience drain problems. The following link explains all this to you.
http://www.fixya.com/support/r389335-basic_washer_installation_tips
I hope this helps you.
Posted on Aug 04, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Have a had a whirlpool cabrio washer for almost 3 years. It started as a small leak when it was draining to huge leak now where all the water is draining out all from the right front side.
Hello, the Cabrio has the drain pump on the right rear. Pull the washer out from the wall about 2.5 feet or so. Place a towel over the top edge of the control panel and lean the washer back against the wall so it rests there. Lay on the floor and, using a flashlight or headlamp, carefully inspect the drain pump for cracks, the rubber pipes for leaks, and check to see if the motor in the middle has water trails that look like water was slung out when spinning. These models are notorious for leakage from the tub seal at the center. Water drains down into the bearings and motor. I've also seen where the body of the drain pump cracks and leaks. Also, check the metal spring clips. They are notorious for being too loose for holding the rubber elbows and pipes on the plastic nipples under the tub--I never use them to repair a washer--I ALWAYS use automobile hose clamps purchased at auto parts stores--way better and DEFINITELY more reliable. You'll need the 1.5" to 2.5" sizes.
Aug 19, 2015 | Whirlpool Washing Machines
My washing machine spins and rinses but does not fill with water and wash, what could the problem be. It is a top loader
Does it pump the water in?, I made a small mistake of just running my drain hose to the floor drain in a basement suite once. with out the hose being up above the rim of washer,the water just runs right on out. made a mount with 2 inch pvc and ran a tube to the drain and it worked then.
Mar 04, 2011 | Kenmore Washing Machines
Whirlpool WTW5520SQ0, when draining the water is coming out at such a fast rate it's backing out of pipe and on the floor.
For many of the new washers you need to have a 2" standpipe and trap... the older 1-1/2" standpipes and traps will not handle the higher volume of the new pumps...
heatman101
May 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Lint build-up on clothing after coming out of washing Machine
ck to be sure drain hose is not more than 6-8 inches into standpipe ..standpipe is 30-36 inches to top from floor ..drain hose does not fit too tight in standpipe any of the above conditions may cause water to siphon out during wash or rinse resulting in not enough water in tub to carry lint away during drain
Sep 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
