Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
Hi. The dishwasher appears not to heat up all the time. The soap drawer does open, but open the tablet does not disolve. This leaves the dshwasher very cloudy and often still dirty. I have also noticed that the place where you can salt is full of water
  • AEG Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 28, 2011
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
Soap tablets are not disolving in the drawer?
Unlike a dishwasher the drawer on a washing machine is for soap powder or liquid. Tablets won't dissolve in the drawer you need to put them in the drum if at all.
Dec 13, 2010 | Washing Machines
Model MDBF550AWB, soap dispenser is not emptying. Soap door opens but soap does not disolve.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dshwasher tablet wnt come ut and dshes very wet
The detergent tablet dispenser door is energized by a solenoid wired directly to timer control board. The drawer will normally open releasing the tablet when the machine starts filling.
If the Drawer does not release the tablet, then either dispenser solenoid is faulty, or timer board mast be replaced.
If the machine is functional but does not release, then the technician will probably need to replace the detergent table dispenser solenoid, that often is built in with dispenser assembly.
You can call support ringing the number listed at the end of the owners manual.
Sep 07, 2009 | Hotpoint Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dish soap not disolving
Is the water heating up? This may be the problem.
Apr 14, 2008 | Dishwashers
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
Soap tablet not disolving
Its has been my experience that those soap block dont do a very good job. Try using a gel type detergent for wahing your dishes
Nov 08, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
234 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
