Question about Canon imageRUNNER C6800 Copier
Hi canon IR 6800 CN error code E000100-0002 this error does not turn on the machine allows continuous Can you give information about this topic Tahnk you
Canon ir 6800cn error code e000100-0002 solution
Posted on Nov 13, 2012
Code error E000078-0001
Posted on Apr 09, 2011
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
First i changed the fuse gear canon ir 6800 and put the fuse unit back to machine . when i turn it on the machine show the error 000005-000010 what can i do ?
hi . that error indicate that the cleaner roll ( in the fixing unit )is over . maybe there is a sensor disconnected or misplaced. check That section and clear error from service mode
copier / function / clear / err ok.
Feb 27, 2016 | Canon Office Equipment & Supplies
How to clear an error fo canon copier ir 6800 cn with an e000061-0001
A E000061 is a drum potenal problem. It means the drum is not charged up correctly. It could be as simple as replacing the two post corona wires and cleaning the grid or making sure the primary charge unit is installed correctly. It may also, be a broking grid or corona wire > you may have to replaced the primary charge unit??? It could also be the drum potenal sensor or the DC controller or the drum..... I'd go for the simple stuff first and you can not clear the problem till the problem is fixed > Before I forget, you can also, turn the drum potenal off in service mode... It's just a band aid, it will not solve the problem..... Good Luck
May 05, 2012 | Canon Office Equipment & Supplies
Canon ir 3100 cn E805 003
E805 fan error
Description
With the ITB fan in operation, the machine does not detect a lock state for 5 sec continuously.
Remedy
Turn off the main power, and check the DC controller PCB; then, turn the power back on.
Remarks
Disconnected fan connector; absence of lock signal because of fault in fan.
Nov 09, 2010 | Canon Office Equipment & Supplies
Error
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
Sep 11, 2009 | Canon iR 2016i Black and White Copier
Error code E000070 0001
this is a error code for the transferf sheet either it is ripped or not turning anymore
Feb 02, 2009 | Office Equipment & Supplies
Error code e000014-0000
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Nov 02, 2007 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER C6800 Copier Logo
1,228 people viewed this question
old marine
old marine
