Question about 2wire 2700HG-B Router (2700HGB)
2WIRE 2701 router
I wish to buy a "generic" 2WIRE router (cheaper than from my EMBARQ DSL provider) and connect to the EMBARQ DSL. How do I program/set-up the router to work with the DSL?
  • donaldwesley Aug 06, 2008
    Thank you VERY much. EMBARQ sells for $149 and I can get them for $75. Your solution seems easy enough and you explained it very well.
    Thank you, again
  • Anonymous Mar 17, 2014
    bought from bell 2 years ago. Not with bell anymore. Want to use router with another service provider. how or what do I need to do ?
    Problem Solver:
  • 19 Answers
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Posted on Aug 06, 2008
  • Javier Ponce de LEon
    Javier Ponce de LEon Aug 19, 2008
    You are very welcome, I hope this worked for you, Let me know once you get the router if you have any other questions.
Can the 2701 HG-B handle 6000-plus Kbps?
According to the setup screen, it can handle DSL link speeds up to 10692kbps (down) and 1036kbps (up)
I can't verify that it works, but... that's what it says
Jan 02, 2013 | 2wire 2700HG-B Router (2700HGB)
The dsl light keeps blinking red no Internet connection
for LED LIGHTS interpretation: refer to this link:http://www.sasktel.com/search/controller//Internet/2Wire-Gateway-2700-2701-LED-Status-Lights-Guide/_/R-Support_13750/Record-Support
NOTE: everything that says contact SASKTEL TECH SUPPORT refers to your Internet Service Provider
Qwest Technical Support at 1-800-247-7285
SASKTEL TECH SUPPORT Anywhere in Saskatchewan :1-800-773-2121
Outside Saskatchewan (anywhere in Canada and USA):1-888-773-2122
Anywhere else in the world:1-306-522-1820
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Hope This helps
Aug 14, 2011 | 2wire 2700HG-B Router (2700HGB)
My dsl light is flashing and the 2wire router just clicks over and over again. All other lights are on and green except for the Internet light (because dsl is flashing). Router has been working perfectly...
Hope This helps
Jun 25, 2011 | 2wire (2701HG-B) Wireless Router
CAN I USE A WPA2 SECURITY WITH THE 2701 2WIRE B-ROUTER
It only supports WPA and WEP. If you need help setting it up, here is a great guide: http://server-servers.com/att-dsl-2wire-2700hg-b-router-setup/
Good luck
Dec 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Will a 2 wire dsl router 2701HG-S work with cable modem
No, not the way you want it to. The wan(internet) port on the 2701 is an rj-11 that will only connect to a phone line with DSL service. There is no way to use this as a router with your cable modem. You need a router that has an ethernet (rj45) port as the wan port.
Oct 05, 2009 | 2wire 2700HG-B Router (2700HGB)
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
2wire 2701HG-S Embarq to AT&T
that is typically a bad username in the modem, you will have to put there temp user name in for registration for the DSL. and after that you can put the username into the modem that you created during the registration process. Should be taken care of.
May 15, 2009 | 2wire Computers & Internet
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
Dsl
try opening a port your pc via the firewall on your router.
Jul 14, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2wire 2700HG-B Router (2700HGB) Logo
617 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
