Question about Toro Lawnmower 20099 Mower Mowers Lawn
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
  • Anonymous Mar 26, 2014
    I have removed the 4 bolts
    Novelist:
  • 111 Answers
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Posted on Mar 30, 2011
Testimonial: "Thank you for your help it was much appreciated, did the job of replacing the blade with no trouble thanks again."
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
How do I put a spring back into a mountfield sp544
sp544??? is it a 534 or 454 possibly? either way i think they have mountfield rv engine,you will need to remove the recoil housing assembly,remove the rope pulley (think the centre pulley screw is left hand thread) then if the recoil spring is undamaged you can wind the recoil spring back into the recoil housing
Mar 10, 2015 | Garden
How to change mower blades
I have seen lots of lawn tractors and never had a left hand thread. I have put a piece of two by four against the blade or vice grips as well.and put a pipe on my wrench and forced it to loosen. Oil the threads before reinstalling as well. Don't over tighten.
Sep 20, 2014 | Garden
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Aug 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Replace blades on Mtd mower deck
no they are not left hand threads if nuts have molded washers you must use an impact gun. wash holds too much of blade surface and will not turn against it
Jul 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
Replacing blades
It is standard threads and should turn left.
May 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a mountfield rotary mower,and i need a new blade but i cannot undoe the existing one.
are you loosening it the right way?as some have left handed threads and loosen the opposite of a normal right hand thread,otherwise take it to a garage and have them remove it with an impact wrench
Apr 30, 2010 | Garden
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
Are blade mounting bolts left or right hand threaded ?
Right hand threads. I just replaced mine. The bolt will turn off in the same direction the blade turns when it is running.
Aug 08, 2009 | Mtd Arnold Corp No. Mtr - 42 - Ec 42" Mwr...
Toro Lawnmower 20099 Mower Mowers Lawn Logo
597 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
