Question about Nokia 5130 Cellular Phone
I am using nokia 5130 .but it was some problem,some times my mobile showing sim card regestration failed
  • Nokia Master
  • 17,130 Answers
Perhaps there is some loose connection of the SIM card to the SIM card holder and contacts. So remove the battery and the SIM card., Use a paper to polish the SIM card contacts and the contacts on the holder. Make sure that the SIM when placed fits well into the holder firmly and in place , If not you can lift up the contacts very carefully so that the SIM never loses contact.
If this wont solve there are errors in the main board which might need more attention with help from Nokia care.
Posted on Mar 28, 2011
Start up phone without simcard?
I am using nokia 2700 classic mobile, some times it shows no sim card available in display. so i switch off my mobile to switch on means it shows Start up phone without simcard?
Apr 30, 2012 | Nokia Classic 2700 Cell Phone
Tip
Codes of 5130
<b> Nokia 5130 Mobile Unlock <br /></b> <br /><br />*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 5130 To view Week and Year of manufacture enter *#3283# [*# D A T E #] <br />The last two digits are the year. If the year is 95, the first two digits are the month. For 96 the first two digits are the week of the year. <br /><br />To view the software version on Nokia 5130 enter *#170602112302# or *#9999# <br />On newer phones, the code has been changed to *#682371158412125# <br /><br />All Nokia phones (Nokia 5130 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) <br /><br />The main code used in Nokia 5130 phones is : <br />#pw+(master code)+Y# <br />This code is able to check, activate or remove Sim card restriction (SP-lock). <br />Use the * key to get the p, + and w chars. <br />'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with. <br /><br />#pw+1234567890+1# for Provider-Lock status <br />#pw+1234567890+2# for Network-Lock status <br />#pw+1234567890+3# for Country-Lock status <br />#pw+1234567890+4# for SimCard-Lock status <br /><br /># = DOUBLE-CROSS <br />W = PRESS "*" THREE TIMES <br />P = PRESS "*" FOUR TIMES <br />+ = PRESS "*" TWO TIMES <br />MASTERCODE = 1234567890 <br />Y = NUMBER 1 TO 4 <br /><br />(master code) is a 10 digit code, based on the phones IMEI number. <br /><br />Eg. To remove restriction on lock 1 type following code: <br />#pw+(master code)+1# <br />If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code) <br />eg. To check if phone if restricted on lock 1 type the following code: <br />#pw+1234567890+1# <br /><br />Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx <br /><br />1. Insert SIM card of different provider. <br />2. Turn on the phone and press the UP VOLUME key for 3 sec. <br />Then release it and the phone says PIN CODE? <br />3. Press the "C" key. <br />4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#<br /><span></span>
on Dec 19, 2010 | Cell Phones
Nokia 5130 c 2 showing code restricted
Restricted code is nothing but the unlocking code, it just removes the sim card restriction and makes free to use your mobile with any network.....
Good place to get a restriction code for your nokia 5130 C 2 model mobile from this site Classicunlocking.com , here get the easy instructions for getting the code for your mobile from the network lock.......
Nov 15, 2011 | Nokia Lands Phones
My 7210 super nova is no service when i open my my 7210 they apear sim regestration field
Clean the Sim Card case and most of the time the Sim case is broken.OK try to remove the back cover and insert your sim card, press and hold to the sim case power on the sim without putting the back cover.If it is working well the problem is the sim case, contact mobile repairing shop to change it.Good luck.Thanks for visiting fixya
Oct 20, 2011 | Nokia 7210
How to unlock my 5130xpressmusic from telcel mexico
Try to get it from online providers..
Aug 13, 2011 | Cell Phones
Dear sir i am using nokia 5130c xpressmusic mobile,the major problem i was facing is it's IMEI number is12345610654321?.and if i insert any sim card it shows that sim card registration failed.please...
I am sorry to hear regarding the trouble. This simply indicates that the SIM has gone bad and needs replacement. You need to go to any of the nearby centers and buy a new SIM ( same number would be activated on the new SIM ). If you are in INDIA, this is a common problem with Airtel.They would charge around Rs 50 for the new SIM and it would be activated within 24 hours.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 15, 2011 | Nokia 5130 Cellular Phone
Nokia 5130 sim card registration failed solution
As if your using nokia 5130 cellular phone your mobile is 100% fine as a new one you just have problem with your sim card the problem is your sim card as got damaged.The reason for sim damage is you have keep your sim card in your valet,or you used to change your sim frequently.The other reason is you have taken a new sim but the service provider company may not recived your address prof from your number or your not using that sim from three months. so you better forget that number and take a new number. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Nokia 5310 Cellular Phone
Nokia3110c sim card regestration fail
Please wipe clean your sim card and get it retry. If still problem, your sim is crashed and need replacement
Feb 06, 2011 | Nokia 3110 Cellular Phone
How to block my lost phone?
If your mobile phone is lost or stolen you can inform your network provider with yours IMEI number who can then put the serial number on a shared database. This list stops this particular phone from registering on any network and will be useless for anyone even if the mobile phone’s SIM card is changed!
Jul 08, 2010 | Nokia 5310 Cellular Phone
Sim card registration failed
Check that sim valid,
Check with another sim card if problem not shows sim card may complaint do as follows
Take the sim crd out and rub gently with a cotton cloth, and reinsert it.
Or take to service provider & ask him to give duplicate sim.
If problem with mobile try to dial *#7370#(Format),
Or take mobile to Nokia care(Problem might be network ic).
Sep 29, 2009 | Nokia N73 Cellular Phone
Nokia 5130 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
