Question about Logitech MX 600 097855036162
After trying with Ni-Cd batteries the mouse seems to not be sending any signals to the receiver. Batteries are working ok in any other decvices. (already tried with normal batteries and is not working either) Any ideas?
  • Logitech Master
  • 17,130 Answers
Failure within the mouse to mesh up with the receiver as there can be internal errors. Since the battery was confirmed then the other option is to open and check for the battery connections in the mouse and the receiver's connection to the PC.
Posted on Mar 28, 2011
Can i get the wireless keyboard n mouse without the 2.4GHz usb receiver
The wireless mouse works by sending a radio frequency (RF) signal between the mouse and a USB receiver on the computer. Unlike a wired mouse, it needs batteries and it also needs to be switched on.
Mar 28, 2012 | Gear Head WIRELESS keyboard/Mouse
Mouse keeps disconnecting
I would check the batteries.
Then check to see if the USB connection on the sending unit is tight--you could try another USB port.
Once installed, the mouse should keep responding unless the batteries are weak. Check to be sure the batteries are inserted fully into the mouse body.
var fctb_tool=null; function FCTB_Init_da2b83355ba44c1f9598b022f96cb3e8(t) { fctb_tool=t; start(fctb_tool); }
Jan 29, 2011 | Logitech Cordless Mouse
Wireless optical mouse #97990 Rev 5 does not work
Remove the batteries. Remove the receiver from the PC. Reinsert and try to link them again.
Aug 31, 2009 | GE Wireless Optical Mouse
Camera will not work after Ni-MH and Ni-Cd batteries used
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Feb 10, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 08, 2008 | Logitech Wheel Mouse Optical
Cant get Pointer to move
First try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Then if that doesn't work try
Hope this helps you. Bud
Feb 19, 2008 | Dynex Wireless Optical Mouse DX-WOM100
It's WIRELESS. The receiver is powered by USB. The mouse needs batteries. AAA in most cases! If batteries test ok in a remote control...they should have enough for mouse.
Nov 12, 2007 | Dynex DX-WOM20 Mouse
GE Wireless mouse 97990 Rev 4 stopped working
From the Jasco website, some other options to try: Batteries: Tracking can be affected by low or dead batteries. Try replacing the batteries with a fresh set and test the tracking. Although you can use rechargeable batteries, alkaline batteries have been found to have the longest battery life. Interference with other electrical products: Other electrical devices may interfere with the radio signal that the mouse uses to communicate with the receiver. Try placing the receiver in a different location, away from the monitor, zip drives, and other electrical devices. Also, try rotating the receiver so it is on its side (or back). Range of the receiver: GE cordless pointing devices can transmit a signal up to 2 meters (appr 6 ft). Make sure the receiver and mouse are within the 2 meters of each other.
Dec 20, 2006 | GE Wireless Optical Mouse
Logitech MX 600 097855036162 Logo
46 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
