Question about Polaroid FLM-323B Television
My Polaroid will turn on but absolutely no picture what so ever, sound works and everything, but when it turns on screen stays black.
    Novelist:
  • 131 Answers
Hello; I am John at J. D. Electronics in Poland, Maine. This set uses a very poor design. They are stacking two 450 volt cap to get a 900 volt rating needed in this circuit. This practice was used decades ago, but only with VERY high quality caps that are closely matched. At least one cap is bad, but they MUST both be replaced with high quality MATCHED caps. There is an 80% chance that these are your problem. If you have no way of soldering and testing Caps send it to me with $40 cash or postal MO to cover parts, testing & replacing caps and return shipping but with NO WARANTY. You must call first 207 998 5687 est. No weekend hours, but OK 9-5 est. Good luck, John
Posted on Mar 28, 2011
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Sep 29, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
Dec 31, 2009 | Polaroid TDX-02610B LCD TV
Polaroid fdm-0700 with black screen display. DVD
go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Aug 09, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid flm373b
Try several different inputs.
Sep 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
TV will not turn on
Try the power supply. Fnd one with the same volt, amp and polarity and try it.
Aug 22, 2008 | Polaroid FLM-2011 Television
Polaroid FLM-323B Television Logo
65 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
