Question about RCA L40FHD41 40. in HDTV
RCA L40FHD41YX9. The picture has not been good for several weeks. It has been fading and then going back to normal. Now the screen is black. The sound works fine. Is it a light bulb? Hopefully something simple. It is 'just' out of warranty.
techman
  • 3130 Answers
SOURCE: Loose Picture (Goes completely Black)
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
Posted on May 17, 2006
  • 537 Answers
SOURCE: Picture Fades
Here is one possible solution:
1. Go back there and get the remote for the RCA.
2. Towards the bottom right you'll see a "FORMAT" button. Press it and look at the screen each time.
3. This changes the screen format between Cinerama, 16:9, 4:3, and all the Zoom formats.
4. ONE of those should be what you're looking for...
Is there a way to reset this TV back to factory defaults through the menu?Try that. Otherwise it is a more serious problem. Call RCA to see if they can help.
Posted on Nov 20, 2007
SOURCE: Buzzing noise, still have good picture
it's the colour wheel,i have replaced it once under warranty and now need another, rca and dlp ****
Posted on Sep 01, 2008
SOURCE: help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
Posted on Nov 07, 2008
SOURCE: RCA Scenium: l5000yx1 - turns on and off by itself.
Mines did the same thing. I had to get a new bulb $200 on line and pay someone $200 more to fix some wires that had pulled apart when we changed out the light. But now it works great!
Posted on Nov 22, 2008
Hello...Have RCA L40FHD41YX9 ,serial number J203C40GV. Watching t.v., picture and sound go. Unplug, then replug...blue light in front, but still no picture or sound. Please advise
Fred, Unplug for a couple hours then try, if does not reset, board,capacitors or power supply gone bad.
Check the attached links for TV's problem.,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fix Your TV Instantly
how to fix 42 RCA flat screen
RCA 276046 Power Supply Unit PSU Boards Replacement Guide for RCA LCD TV...
http://v6.tvrepairtips.org/anon/supertips?page=1&make=&model=LTV46W1%20HD&problem=
Mar 07, 2016 | RCA Televison & Video
Why is the screen going black on my RCA 7 inch tablet?
If you cannot bang it back to life then get a new one and don't drop that one. Repair is too expensive.
Nov 19, 2015 | Tablets & eReaders
My HDTV has gone out.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 14, 2015 | RCA Televison & Video
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
I have a rca hd56w66, my screen shuts off but the audio still stays on. For a few days, it started fading to orange and then to green and then out to black. After about a minute, the picture would come...
Sounds like you lost the power supply to guns, now this doen't mean you have to go looking for it, you will need a repair person to fix it. Word of advise, if you haven't had one of these fixed before it can range in upwards of 600.00 or more to fix now days.
Oct 09, 2009 | RCA HD56W66 56" HDTV
Picture Fades
Nov 20, 2007 | RCA HD52W59 HDTV Projection Television
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
May 16, 2006 | RCA MM32110 TV
RCA L40FHD41 40. in HDTV Logo
117 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
