Question about Whirlpool Washing Machines
The small detergent section of the tray always stays full of water. is that normal?
    Brigadier General:
  • 6,277 Answers
No, not full. I suspect that the conditioner/softener tray needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
Good luck,
John C
Posted on Mar 28, 2011
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Why does water remain in the fabric softener tray after a load has finished?
If you are getting good water flow through this section on the final rinse then it can only be a blockage in the tray itself.If you take out the drawer by depressing the button in the centre of the drawer.then wash all the old detergent under the tap.Then remove the small insert in the fabric tray you will see normally 3 raised tubes,these need to be clear and also the part that sits over them,you should clean it thoroughly then refit and try again.
Hope this helps.
Jun 09, 2010 | Electrolux AWF1235 Front Load Washer
Leaking water
Water can't leak out the top from overloading unless the entire tub is full of water which is a major malfunction, or an inlet hose between the powder drawer and tub is somehow blocked (extremely unlikely).. Are you using topload detergent? Normal detergent can foam up and out through the drawer and leak onto the floor..
Normally water enters through the top of the powder tray to disperse it into the tub. pull out the tray slightly while filling to see how this works. You might be able to identify that the water is not flowing properly. Normally you can really pack into a front loader, I've been thrilled with my 5100 for 8yrs.
If this doesn't help let me know and I'll suggest next step.
May 14, 2010 | Whirlpool AWM5125/1 Front Load Washer
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Sep 09, 2009 | LG Washing Machines
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After washing clothes, water stays in the detergent tray.
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
A.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch 300 Nexxt won't use detergent on cold cycles
Make absolutely sure you have the hoses connected to the correct inlet valves,it sounds to me as though they are the wrong way round.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Bosch Nexxt 300 Series WFMC2201UC
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
