Question about Polti VT1300 Vacuum
My polti vaporetto 1300 is blowing steam out of the tube input socket. Is there some valve which could be stuck? Any help on how to fix this, please?
5 Suggested Answers
SOURCE: Polti Vaporetto
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Posted on Dec 04, 2007
  • 17 Answers
SOURCE: NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Posted on Mar 11, 2008
  • 389 Answers
SOURCE: How do I undo the torx screws that hold the Polti
With a torx screwdriver! There's nothing special about these screws except the shape of the hole in the head. Commonest size in small domestic machines is T15.
Posted on Oct 15, 2009
Ranglo
  • 1194 Answers
SOURCE: lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
Posted on May 31, 2010
Lost instructions for vaporetto polti 2400
Good Luck
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Vaporetta polti VTT2085 1998
The solenoid isn,t operating. Either the valve is stuck or the coil is burnt out
Dec 26, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam polti 2001r, heats up clicks, but no steam!!!!!!
the solenoid valve isn,t operating when you pull the trigger. It is caused by either the coil has burnt out on the solenoid or the valve itself is stuck
Nov 06, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti VT1300 Vacuum Logo
174 people viewed this question
Top Polti Vacuums Experts
Jose Pino
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
