Question about Palm Pre Plus Cell Phone
Why can't I get my phones main ringer volume to turn up? It will only vibrate. All other sounds work, you tube and pandora work fine.
  • jhowardsns Mar 28, 2011
    it's a palm pre web OS 1.4.5.....i know how to turn up the volume. When I try to turn the volume up on the left side of the phone nothing happens. When I press the volume up button the bell appears on the botton of the screen with a slanted line through it like I had instead turned the volume all the way down. Even when I go into system sounds all volume is set at the highest levels. Alarm sounds work, and all other sounds work. I just can't get any ringer volume or message alert sound. Please help. Thank you.
    not sure if I told you what model the phone is. It a palm pre web OS 1.4.5....
  • 2,574 Answers
I recommend a reset.First, slide out the keyboard on the Palm Pre .
Next, at the same time hold down the "Orange", "Sym", and "R" keys to reboot the Palm Pre. If nothing happens, try again and hold the keys for longer this time. By now your Palm Pre should be restarting,if this did not work, try removing the battery and waiting 10 seconds before re-inserting and restarting the Palm Pre.
Posted on Mar 28, 2011
  • Palm Master
  • 6,993 Answers
is it that you don't know how to turn the ringer volume up or you turned ringer volume up to the highest but it's still low? Also what the name and model of your phone?
Please very this question for straightforward answers.
Hope to hear from you soon. Bye for now.
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I dont know how to take off my silent mode
hi justin,
you may wanna visit this link for reference:
http://www.samsungtelecom.com/PDF/A460.pdf
to change the ringer volume from the main menu:
1.press menu for menu options
2.press 8 for sounds
3.press 1 for ringer volume
4.press 1 fro calls
5.select off/vibrate/1-beep/level1-8/ring+vib,and press ok
Apr 14, 2011 | Samsung SPH-a460
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you turn the ringer off on KX- tg4011 serries telephone?
Some phones, like the iPhone, have switches that will turn your phone on vibrate. If it doesn't have anything like this, go into the Settings, look for your Sound Profiles and turn the ringer volume down. This will make it so you don't hear anything when receiving a phone call though, so you'll want to turn the vibrate function on if possible.
Jan 24, 2011 | Panasonic Cell Phones
The iPhone does not ring, only vibrates
There's a switch on the left side at the top of the iphone that turns the ringer on and off. Make sure this is towards the front of the phone to enable the ringer
Jul 26, 2009 | Apple iPhone 3GS Black (16 GB)
I cant put my text mesg on vibrate
Navigate to Settings > Sounds > Volume > Messages > Text Message. Vibrate on needs to be checked. Lower the ringer volume by clicking the left arrow.
Apr 09, 2009 | LG Lotus Cell Phone
Palm Pre Plus Cell Phone Logo
88 people viewed this question
Top Palm Cell Phones Experts
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
