Question about Saniflo & Saniplus& Macerator Pump
What should I clean my saniflo toilet with please?
What should i clean my saniflo toilet with and how often
Posted on Apr 24, 2011
I have a saniflo system I just installed....what is the best type of toilet paper to use? And should I flush the toilet more than once to insure it stays clean?
many consumers prefer Charmin ultra soft .not necessary unless it doesn't go down the first time . Just wasting water .
Oct 04, 2015 | Saniflo Home
I just bought a new house and the saniflo toilet is fairly loud. is there something that I can put in it to clean it out.
If the unit is making a loud noise then there could be an obstruction in the blade or impeller, you will have to pry open the lid using a flat head screwdriver and then remove the motor out of the casing, the blade is on top of the motor and the impeller is at the bottom of the motor.
Saniflo recommends using any cleaning products that does not contains bleach or chlorine such as liquid lysol, Mr. clean or simple green. Also Saniflo sells a descaler that is designed to clean the inside of pump casing.
Jul 12, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo Top: Pump
indicates perhaps a faulty pressure switch. otherwise: this happens often in hard water areas due to build up of limescale. Use a descaling agent (acidic) to clean the saniflo - can be introduced via the toilet bowl.
Apr 02, 2010 | Saniflo & Saniplus& Macerator Pump
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflo will not pump out and water is backing up in the sink
Probably blocked on the intake pipework. You'll need to get the Saniflo out, clean out all the build up from the inside and try again. It is probably an idea to try and clean the pipes as well.
Not really advisable to use Mr.Muscle or other drain cleaners on the Saniflo range as it can eat the seals.
Good luck
Jan 04, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
It is blocked how do i unblock it
Turn off electricity to saniflo.Turn off water to toilet (normally an inline valve). Empty toilet bowl and cistern of water. Remove toilet, cistern. Disconnect inlet pipes to saniflo (careful as backed up water will flow out!).
Take out Saniflo (outside is normally good). Open up top with star driver and use a flat blade for the plastic retaining flaps.Be sure to wear rubber gloves to keep out germs from cuts etc on your hands.
Cover mains cables with plastic food bag and tape up. Use a solution of bleach / warm water, fill up the sanifo and leave for a while. Swish around and empty into a drain etc. I also use a hosepipe to make sure I get it really clean (esp under motor and float switch). Also check inlet pipe flappy bit and the actual pipes that connect to the saniflo
Good luck
Dec 19, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
How do I keep my saniflo toilet clean?
use easy off bang 2 solce ur problm
Jul 06, 2009 | Home
WHERE TO FIND AND PRICES FOR SANIFLO BASESMENT TOILETS
Here are a few sites just copy and paste any of these in your browser.
http://www.needplumbingsupplies.com/NeedPlumbingBrands.asp?MfgRqst=10 (this all one link...)
Here is the Saniflo homepage
http://www.saniflo.com/?gclid=COaXi8vxyJkCFQENDQodOnOjsg
Next tag
http://www.nextag.com/saniflo-toilet-systems/products-html
and one more...pricegrabber
http://indoors.pricegrabber.com/bathroom-toilets/saniflo/p/1538/
I hope this helps and good luck...and thanks for rating my effort....the Fang
Mar 28, 2009 | Saniflo & Saniplus& Macerator Pump
Leaking cystern
turn water off flush scoop out water remove 2 screws on side of toilet lift toilet off clean replace wax ring reinstall
Jan 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo & Saniplus& Macerator Pump  Logo
978 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
