Question about Micromark Heating & Cooling
STMS - 170 - A Storage heater stopped working, Circuit, switch , elements and all internal controls appear to be ok. Any ideas???
3 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Storage Heater
You will need a volt/ohm meter. remove the element or at least the wires on each end. set the meter to ohms, touch each lead from the meter to the opposing ends of the element. The meter should have some type of resistance. If it shows open or the needle doesn't move (on the older non digital type) then the element is bad.
Posted on Jan 05, 2008
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
Gecko blown heater fuse
check recirculation pump and heater element and temp sensor and pressure switch
Mar 10, 2018 | Pool & Spa
STMS STORAGE HEATER NOT WORKING
If you have power at the elements.the elements are bad.
Nov 11, 2015 | Water Heaters
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Neff b1861 oven fan and interior lights not working on Circotherm settings
sounds like the control switch to me. if you have already taken it apart it's the switch with the most wiring.
Mar 21, 2014 | Ovens
KEYPAD BUTTONS STUCK
The touch pad sends a signal in sequential orientation that starts and stops various functions. When the controller sent a message to the heater coil to disconnect it failed to negotiate the command. The problem therefore is the electronic switch in the heater circuit. It could also be as simple as a temporary short due to moisture buildup on sensitive electronics and connections. Check all internal wiring for disruption or damaged insulation.
Mar 18, 2014 | Maytag Dishwashers
Elite troubleshooting
unplug/remove power from device.. check heater element with a volt/ohm meter if ok , check timer for burnt contacts or circuit board for burnt connections, may be an internal logic failure if its electronically controlled(bad board/controller)
Mar 15, 2014 | Dishwashers
Pontiac g6 code P0054
Hi. Generic code description is
O2 sensor 1 bank 2 Heater control circuit.
Means the heated oxygen sensors internal heating element isn't working. Visual inspection of wiring and plug then if that's ok and you haven't any live data its probably worth a shot at replacing the O2 sensor itself. You can check the resistance of the heater element with a multi meter on ohms by disconnecting the O2 sensor plug and compare it to the other sensors for a guide if your technically minded. Jon.
Dec 15, 2013 | 2006 Pontiac G6
Storage part of heater not working boost working fine
It sounds like the storage heating element has fasiled and/or the associated thermostat has failed. With the mains power disconnected a multimeter could be used to test the continuity of both the element and thermostat. You should get a low reading (under 10 Ohms) on both if they are OK. If either item reads a very high restince or open circuit, then they will have to be replaced.
Dec 01, 2010 | Heating & Cooling
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
K 484A fan forced wall heater
You need to check its plug and external wiring.. may be worn out.
Oct 14, 2008 | QMark LFK304 Fan Forced Wall Heater -...
Heating & Cooling Logo
155 people viewed this question
Top Micromark Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Micromark Heating and Cooling Expert? Answer questions, earn points and help others
