Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
Very slow water flow into ice maker and almost no flow from water dispenser. Replaced filter, did not fix problem.
    Scholar:
  • 116 Answers
HI if your using a saddle valve to connect your water to to main water line, this is the problem either switch to a regular T-reducer or try to drill the hole bigger in the saddle valve, those wil restrict the flow to your refrigerator.
Sean
Posted on Mar 28, 2011
How do I fix my water dispenser?
The ice maker would fill slowly even if you only have a "dribble".
It sounds as if your filter light may in error and the filter may need to be replaced. Unless the one your refrigerator uses is very expensive I would replace the filter before calling a technician. If that does not solve the problem, try googling for an answer to your question. Others may have had a similar experience and know the
cause and how to correct it.
May 19, 2014 | Maytag Refrigerators
Door dispenser not working
Is the ice maker working properly? There is a water filter in the refrigerator through which both the ice maker and water dispenser are supplied and over time it will slow down the flow and eventually block. Have you changed it recently? Often, ice cubes will get smaller as it blocks and the ice maker will also quit.
Also, have you checked the water supply line that goes to the ice maker and water dispenser? It should be a small diameter copper or plastic line that connects to the back of the refrigerator.
Ed
Jan 08, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
I've just replaced the water filter and the flow rate on the water dispenser is as slow as it was before. I ran the dispenser to remove the air from the system so I know that is not the problem. The flow...
Hi and welcome to FixYa, I am Kelly. Most water flow problems that are common to both the ice maker and water dispenser are either a supply volume or filter problem. Since you already have replaced the filter that points directly to a supply volume problem. Water connections for refrigerators are often connected by using a saddle valve on the side of a water pipe. The saddle valves have a rubber gasket that is clamped to the side of the pipe to prevent leakage. The gasket over time can swell due to being clamped or plumbing debris can block the small hole that ports water to the refrigerator water supply.
Here is what I recommend. Disconnect the water line where it connects to the back of your unit. If you have the press in type connection (no visible fittings) at the water inlet valve I recommend you get a brass compression coupling and cut the plastic line vs pulling the plastic line out of the water valve. Install the coupling on the plastic line so you will have a connection to check the flow rate.
The incoming flow rate should be the same as the water dispenser flow rate. If the incoming flow rate is faster then the problem is with the refrigerator internal plastic tubing. Most of the time when this discrepancy appears it will be in the door hinge area that the tubing is flattened causing a restriction in water flow. Since you are having both ice maker and water dispenser problems... your problem most likely is strictly water supply line related. Correct the water supply problem.
Thanks for choosing FixYa,
Kelly
Nov 14, 2010 | Frigidaire FRS26R4A Side by Side...
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Ge profile refrigerator slow water dispenser
you have a seperate valve for ice maker and water dispenser, though it is possible both could have debris preventing proper water flow, i would check the water pressure you have going into the valve solenoid housing. turn off water to fridge, disconnect the line at the fridge, not in basement at saddle valve. place end of tube in bucket, turn on water. how is pressure? good or slow? if its good, then you probably do need to replace valve solenoid housing. You can NOT clear debris out of these, they must be replaced.
If your water pressure is still not good, either y ou have a kink in plastic water line. Despite having changed saddle valve in basement, if the stem of saddle valve is mounted on bottom half of pipe, debris from pipe is getting into water line and so on. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
No water flow to Ice Maker or water dispenser
There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the flow of the water causing it to freeze at the dispensing part in the ice maker. Look at the ice maker from the side and you can see the little plastic piece where the water comes down. Reach up and feel to see if there is ice caked inside that piece. If there is you most likely need to change the filter and defrost the freezer. If something else is the problem I can't help you there, lol... this is just from my personal experience.
Mar 21, 2009 | KitchenAid Refrigerators
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
363 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
