Question about Blueant X3 Charging USB 2.0 Data Cable (Bluetooth Headset)
I have a nokia x3 slide.. im having toruble using the headset bec its not going to the headset when im trying to use it,, its always on loud speaker whne i want to listen to mp3's.. also same with the usb outlet.. but the usb is working when we just use it for the purpose of charging..
  • 2,069 Answers
Clean the headset interface jack, and make sure the headset is not faulty. otherwise, try in a another headset. is same, have your phone checked since that could be a problem with phone.
Posted on Mar 28, 2011
Im using nokia X3-00 made by hungary , but i can't
you just go software udate for this process no other option
May 19, 2012 | Nokia Lands Phones
Hai,im using nokia x3.if im charging it, it doesnot get full and it always saying *BATTRY LOW*.If im using this phone i have to charg it while im using it and this thing is stressing because if im going...
HERE'S THE ANSWER TO YOUR PROBLEM:
I believe that the main culprit is your battery itself - its capacity to hold and supply power to your cellphone. These are some of the causes why cellphone battery life are shortened:
1. Bluetooth - it quickly drains battery life
2. Programs running in the background
3. Wi-fi and Data Connections
4. Backlit Screens
Nokia x3 batteries have only 11 hours life when used for calls. So, if in case your battery does not work well, do not think twice to buy a new one. Your battery might have been used up or burn out. Do waste your time bringing charger and charging it always whenever you have calls. Try to think.
I love answering your question. Thanks...
Jul 17, 2011 | Nokia Cell Phones
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
I have made connection between nokia BH-503 and my laptop operating windows 7. But after that when i am trying to connect with my nokia x3 mobile and BH-503 the mobile do not able to find the head set.
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
Nov 29, 2010 | Nokia BH-503 Bluetooth Headset
Speakers feedback through my Barracuda Mic
if have a camera already connect on your pc try to unplug the mike of your camera or go to the audio device manager and change the settings.
Jul 06, 2009 | Razer Barracuda Gaming Headset
Loud speaker problem in my nokia 5300
That is the biggest con of Nokia 5200 and 5300.I've read reviews that Speakers emit noise in just 3 days of heavy use.Only solution is to use a headset:)
Apr 05, 2009 | Nokia 5300 Grey Cellular Phone
Loud speaker is not working
Hi
You have defective loud speaker.. repkace a new one
Thanks!
Oct 17, 2008 | Nokia 6300 Cellular Phone
Blueant X3 Charging USB 2.0 Data Cable (Bluetooth Headset) Logo
137 people viewed this question
Top Blueant Cell Phones Experts
William Alequin
Are you a Blueant Cell Phone Expert? Answer questions, earn points and help others
